How to identify used camshaft
Old Sep 12, 2004 | 06:44 PM
ktg's Avatar
ktg
I'm wondering how to properly identify a used camshaft so that I don't 'get the shaft'?
Old Sep 12, 2004 | 07:02 PM
stang_killa94's Avatar
Re: How to identify used camshaft
I guess to truely check for a used cam, you would have to measure for taper or wear on the lobes.
Old Sep 13, 2004 | 01:44 AM
amean94ta's Avatar
look for light scratches before and after the point of the lobe a new cam wont have them
Old Sep 13, 2004 | 04:22 AM
sssalah's Avatar
The camshaft should have numbers, check those with the manufacturer. If it's installed in an engine you can get the duration and lift with a degree will kit. The lift can be checked with a vernier or micrometer, by measuring the lobe height and subtracting the base circle from it and multiply by rocker ratio to get valve lift.
Old Sep 13, 2004 | 04:48 AM
amean94ta's Avatar
yeah wow these pills must be kicking my *** cause i read and did not understand sorry
Old Sep 13, 2004 | 09:39 AM
ktg's Avatar
ktg
OK. Thanks all.
Old Sep 13, 2004 | 09:44 AM
rskrause's Avatar
Moderator
A used cam will have obvious wear marks on it.
Rich
Old Sep 13, 2004 | 02:37 PM
OldSStroker's Avatar
OK. Thanks all.
Did you mean "used" as in having been run in an engine, or did you mean "without documentation" which specifies the grind or lobe profile, lift and LSA?
You got both answers above, but I'm curious as to what you wanted to know.
Old Sep 13, 2004 | 02:39 PM
ktg's Avatar
ktg
I meant "without documentation" which specifies the grind or lobe profile, lift and LSA.
Old Sep 13, 2004 | 05:01 PM
If you REALLY want to know, and it's a custom grind, and the lobe numbers are not etched on the back of the cam, you should Cam Doctor it (or use an equivalent system) and correlate that with known lobes.
If it's an off the shelf grind from Comp, Crane, GM, etc. there should be a number which you can check as sssalah said.
IMO, used cams, (or unmarked cams) are similar to used brides; you don't really know what you are getting into.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
