How hot should my car get ???
Old Aug 8, 2003 | 11:48 PM
cmbob67's Avatar
How hot should my car run in 90 degree weather. I got a 160 degree thermostat and I just flushed the system. It seem's to run about 210 - 215ish. Is that normal??? Seem's a bit high, but I'm not sure. Any Thoughts????
Old Aug 9, 2003 | 12:02 AM
Depends on how much air is moving across the radiator. Also make sure you bled any air out. More info about the cooling system here.
Old Aug 9, 2003 | 12:36 AM
RedPhenx's Avatar
if you havent changed when the fans come on, then your car will run cool while you are moving... but as soon as you sit still, the car will heat up until the fans come on at 220 (I think)
calaban
May 18, 2020 06:43 PM
Britbilly
Jan 7, 2015 08:49 PM
Collector Car
Dec 17, 2014 01:12 PM
USAirman93
Nov 24, 2014 03:37 PM
GigaMp3z
Feb 20, 2003 02:57 PM
