Heads & Cam
Old Aug 8, 2003 | 09:15 AM
BlkDth's Avatar
Heads & Cam
Will a heads and cam package put more stress on your engine? What other things will you have to upgrade when doing this? Is it still recamended with a 90k car?
Thanks in advance...
Old Aug 8, 2003 | 09:16 AM
Cmr0z28's Avatar
nope, a heads/cam combo will not hurt your car. nitrous or forced induction will.
Old Aug 8, 2003 | 09:25 AM
Perry93TransAm's Avatar
It is all releative, If you put a large cam in with alot of spring pressures the RPMs that youre required to rev to acheive optimum power with your combo will put more stress and wear on the engine. But relatively less compared to forced induction or nitrous.
Old Aug 8, 2003 | 10:29 AM
BlkDth's Avatar
Thanks for the help.
Old Aug 8, 2003 | 11:15 AM
95TA8280's Avatar
It won't put stress on the car unless YOU put stress on it. If I have a stock car and everyday I drive it like I stole it, that puts stress on the engine. If you have a heads/cam combo with 360 RWHP but baby the hell out of it, there's no stress.....
Old Aug 8, 2003 | 11:42 AM
If you increase the dynamic compression of an engine by a cam change it will put more stress on it than the stock cam would have.
Old Aug 8, 2003 | 11:47 PM
mebanditws6's Avatar
Assuming the motor is in good shape, don't spin the motor any higher than 6600 or so (close to 7k on a balanced stock crank and rods), use M1 0w40 or a good 40wt synthetic oil, and the bearings should be ok. I'd also switch to a 160 t stat from increased compression.
Jason
Old Aug 9, 2003 | 12:42 AM
MTL_Z28's Avatar
What are important things to consider when trying to buy the right heads and cam combo for your car?
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
