How hard to change a fuel pump????
Old Apr 4, 2004 | 07:28 AM
97s10ondubs's Avatar
I think im about to change mine, which i think is the problem but just gauging how much work and how long it will take. If anyone has done it before are there any tricks i should know? Thanks in advance.
Old Apr 4, 2004 | 08:00 AM
30thannZ28's Avatar
If you cut an access panel, not very hard. If you drop the tank you wil need the basic hand tools plus three important things.
1. A buddy
2. More than a few cold ones
3. Patience.
Seriously, once you drop the tank or get the pump assembly out through the top by cutting, it goes together rather intuitively.
Old Apr 4, 2004 | 08:07 AM
cut what? a hole in the trunk?
Old Apr 4, 2004 | 08:17 AM
Mystic95Z's Avatar
Yep. There is a guide posted somewhere to help, dont remember where though. I cut the access panel in mine and it made access to the pump a breeze. I didn't have to change the pump though, I was blowing out the evap lines when I was having emissions trouble and put the air hose on the wron line and blew the line off the pump! DOH! It was either drop the tank or cut the access panel. I'd prolly still be workin on it had I dropped the tank...
-Tony
Old Apr 4, 2004 | 08:21 AM
texasTA's Avatar
Just do a search for "fuel pump installation" or "fuel pump guide". The trap door is by far the easiest way.
Old Apr 4, 2004 | 10:19 AM
Red96Lt1's Avatar
1-2 hours, not including time for the glue to dry.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Deadbolt24
Jan 19, 2015 01:29 PM
ANDYZ28
Dec 29, 2014 09:13 PM
30thZ4C
Dec 26, 2014 05:09 PM
