how to get seatbelts off???
Old Sep 6, 2003 | 12:52 AM
cals400ex's Avatar
i need to get the front seatbelts off. i am installing a new seatbelt guide on the side of my seat. i need to get the seatbelt off so i can run it through the guide. how is the best way of doing this? thanks
Old Sep 6, 2003 | 01:01 AM
atljar's Avatar
Unbolt it from the floor. Its under that plastic cover, and is screwed in with a large torx screw
Old Sep 7, 2003 | 12:19 AM
cals400ex's Avatar
how does that plastic cover come off? i tried for a few minutes and didn't see how it came off. i assume you mean the round plastic piece that has a + in it? thanks
Old Sep 7, 2003 | 12:29 AM
atljar's Avatar
Kinda tricky. The circle part turns (you can use a screw driver to turn the + thing), as you are spinning it, pry up on the circle shape and it will kinda pop off. It may take some force, but the plastic is very pliable and wont break easily.
MasterEvilAce
Classic Engine Tech
Sep 7, 2003 11:52 AM
after the fire
Classic Engine Tech
Aug 6, 2003 05:29 PM
Marky82
Jan 7, 2003 04:56 PM
sfGi8nt
Oct 12, 2002 12:52 AM
QUICK305
Jan 29, 2002 12:04 PM
