How to get into the high 10s N/A?
Old Jun 24, 2003 | 03:32 PM
  #16
rage366's Avatar
Originally posted by treyZ28
600
i thought it was 450-475
600rwhp is a lot
600rhwp
450? uhm, suuuuuuure, trey.
sorry, the two cars that i know of who get in the 10 seconds, they were 600+ rwhp...
but, hey, what do i know, my eyes could've been decieving me...lmao.
oh yeah, i believe those two cars were in GM tech...about 1.5 yrs ago.
  #17
FacelessZ's Avatar
M6 = hp? Not at the track...
Old Jun 24, 2003 | 03:42 PM
  #18
thewinner's Avatar
Wrong Again! This car was Jordons daily driver. ~500rwhp. Full interior, rollbar, etc. all on a 6spd.
Old Jun 24, 2003 | 04:09 PM
  #19
xxsaint69x's Avatar
my buddies LS1 (473 rwhp) 6spd ran a 11.05 @ 124 at the track last sunday in 95 degree heat. so i guess it doesnt take 600 rwhp to run high 10s
Old Jun 24, 2003 | 04:24 PM
  #20
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
weight, torque and drivetrain play a role i'm sure
Old Jun 24, 2003 | 04:31 PM
  #21
Mindgame's Avatar
It depends.
If you can get the car weight way down and cut really slick 60' times (let's say in the 1.5 sec or quicker range) then you can go tens on alot less hp. Of course there's more to it than hp but isn't there always?
-Mindgame
Old Jun 24, 2003 | 04:54 PM
  #22
Fastbird93's Avatar
Guys I have the issue of GMHTP with the article on Jordon's car. 471 HP, 455 TQ, motor displacement was 401 CI. AFR heads flowing 295/222 and a solid roller cam. I'm thinking big cam.
Article says he went 10.80@130 with a 1.4 something short time.
Prior combo in the article had him with a 383 with AFR's and solid roller making 390 rwhp going 11.30@123.
Probably 450ish at the wheels and a good 1.5 sixty and you're biting high 10's.
Old Jun 24, 2003 | 10:16 PM
  #23
treyZ28's Avatar
Originally posted by Mindgame
It depends.
-Mindgame
no its all about hp. no other variables. I'm sick of your answeres.
you could write a 550 page discussion on "what color is the sky" with 2736 different variables, optimal sun positoin and a lew of other things
I like my bigger is always better no matter what theory
very simple. works in bed too
Old Jun 25, 2003 | 03:16 PM
  #24
ProtoX's Avatar
What is the biggest streetable cam I could use? I have another Lt1 block bored .030 over should I go with a 383 or a 355?
Old Jun 25, 2003 | 03:56 PM
  #25
AlexsZ's Avatar
Originally posted by poloz28
only way you are doing that N/A is if you get an LS1. lt1 can do it if you spray or boost it.
Guess this guy didnt get the memo....
Old Jun 25, 2003 | 03:59 PM
  #26
rskrause's Avatar
Moderator
Can't be answered. What's "streetable" to one guy isn't to another. About all that can be said has been said. You need: weight reduction, solid roller, good heads and exhaust and it's quite possible. Lots of $$$ though, especially in the heads.
Rich Krause
Old Jun 25, 2003 | 04:09 PM
  #27
Will84's Avatar
The best way to have a "streetable" 600hp car is to do it with boost. Turbo in my opinion. Turbo is also easier on your whole drive train. You might not pull the front end out of the hole... but you won't blaze the tires either. The difference between a 600hp N/A car and a 600hp turbo car is ..... the turbo car can do it on the street and the track. The n/a car is hard to utilize on the street... you will also break a lot of sh it. (i.e. tranny, rear end, driveshaft..etc.)
Old Jun 25, 2003 | 04:39 PM
  #28
KEITHZ06's Avatar
It can be done but to get there N/A it woul be marginal for the street. I run 4.88 gears and had to switch to manual brakes.(the cam profile left no vacuum to run the booster.Although I am not driving it on the street anymore it might be possible. but to Pass emissions I doubt it.
Old Jun 25, 2003 | 07:30 PM
  #29
rage366's Avatar
trey, i'll send ya 500lb woman for x-mas...seein as how you like everything BIG...
Old Jun 25, 2003 | 07:35 PM
  #30
rage366's Avatar
well, actually, if i recall correctly, these two cars weighed more...seein as how one was a t-top and the other was a convertible...guess i kindda forgot to mention that. heh.
but, yeah, they got in the 10's with that...hmm, if i look around, i might be able to find that article...i'll get back to ya on that...
