How is driveability with the Crane 227 cam on the street?
I would like to know how the driveability is with the Crane 227 cam. Does it have a lot of cam surge, and is it a good cam for an everyday driver on the street with a good tune. Also, what stall converter would be recommended for a A4 car with this cam? I would also like to know if it has good vacuum for power brakes. Does it make good power and torque, compared to the Hot Cam. Thanks, everybody
Re: How is driveability with the Crane 227 cam on the street?
It's wonderful for the street. Mine will only surge on a hot start when I'm
driving really slow, and only for a very little bit. It's as close to stock as
it gets. I have not measured vacuum, but I can next time I run the car.
I have no idea regarding stall. The cam has great off idle torque with the
manual so I would imagine you could get by fine with a stock stall if you
have 3:42s. I also have no idea how it stacks up to a hot cam.
Check out posts by speed_demon24 for lots of info regarding this cam.
He ran very strong with it and probably regrets swapping it out for the
GM 846 (222/230).
GM 846 (222/230).
GM 846 (222/230).
GM 846 (222/230).
oldschool
Feb 9, 2016 09:21 PM
