How does this look so far????
Old Mar 19, 2007 | 01:06 PM
94_camm's Avatar
I did the fernco 4inch to 3inch off the throttle body the put the MAF Sensor on the other end.i tapped the opti vaccum into it is it fine??
Old Mar 19, 2007 | 01:12 PM
hotrod18_69's Avatar
Yeah, looks good to me.. I like it!
Old Mar 19, 2007 | 01:49 PM
oneclean97z's Avatar
clean setup man
Old Mar 19, 2007 | 03:19 PM
94_camm's Avatar
thanks guys!You think i can also tap the IAT Sensor into that??
Old Mar 19, 2007 | 03:26 PM
94_camm's Avatar
Now the vaccum line that runs from the opti to the intake manifold do i need the one with those vent things on them or can i just run a piece of regular vaccum tubing??
Old Mar 19, 2007 | 06:05 PM
The 3"x3" connector works just fine.
Old Mar 19, 2007 | 07:07 PM
94_camm's Avatar
Weres your MAF Sensor?where did you tap in your IAT sensor?
Old Mar 20, 2007 | 12:17 AM
LiENUS's Avatar
My guess is. Hes not running a MAF sensor. Hell hes not even running the stock pcm.
Old Mar 20, 2007 | 07:18 AM
94_camm's Avatar
Gotcha ya
Old Mar 20, 2007 | 11:38 PM
Correct.... no MAF. The IAT sensor is in the airbox, stock location - see the gray clip on it? Actually there's two IAT sensors, the other one is right at the edge of the photo, one for the MoTeC ECU and one for the stock PCM.
