How do you remove/replace rocker studs?
Old Dec 30, 2008 | 08:51 PM
Malice 1's Avatar
I've got my engine halfway torn apart, and I'm swapping in a hotcam.
I bought ARP 3/8 rocker studs. What is the best way to pull the stock studs out?
Old Dec 30, 2008 | 08:53 PM
mdacton's Avatar
you unscrew them, lefty loose
Old Dec 30, 2008 | 09:07 PM
Malice 1's Avatar
Yeah, but how? Do you put a double nut on them or something?
Old Dec 30, 2008 | 09:30 PM
Stl94LT1's Avatar
No, just get a deep-well socket and unscrew them.
Old Dec 30, 2008 | 09:54 PM
Malice 1's Avatar
The ARP studs that I'll be installing have a hex at the bottom, so I can screw them in with a deepwell socket.
The stockers don't have that. They screw directly into the head with no base hex.
Old Dec 30, 2008 | 09:59 PM
Stl94LT1's Avatar
Are you sure? These are stock 1994 LT1 heads?
Old Dec 30, 2008 | 10:30 PM
Malice 1's Avatar
THey are stock iron LT1 impala heads, according to the casting #. I guess I should have said that earlier.
Old Dec 30, 2008 | 10:41 PM
Stl94LT1's Avatar
Oh, those may not be screw-in studs. If not, I have seen stud pullers you can buy. But, you would have to have the heads machined for screw-in studs.
Old Dec 30, 2008 | 10:47 PM
Bowtie4life's Avatar
why do you have iron impala heads on your camaro?
Old Dec 30, 2008 | 10:50 PM
The_Bishop's Avatar
Those aren't screw-in studs, they're press-fit. Only way you're changing those is by pulling the heads and machining them.
Old Dec 30, 2008 | 11:21 PM
Stl94LT1's Avatar
Sounds like it may be time for a set of aluminum heads.
Old Dec 30, 2008 | 11:29 PM
sbs's Avatar
sbs
why are you replacing 3/8 studs with 3/8 studs?
Old Dec 31, 2008 | 12:50 AM
TheChronic's Avatar
Ya, those are press fit.
Old Dec 31, 2008 | 05:17 AM
Malice 1's Avatar
it had them on when I bought the car. Plus, I'm told they flow better than alum heads.
because I didn't want to buy new rockers, and I'm not installing a big enough cam for 7/16 studs.
that blows. I guess I'll send back the studs.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
