how do you properly shim a starter ?
Old Sep 29, 2008 | 10:35 AM
blubird's Avatar
how do you properly shim the starter on the lt1 and what exactly does it mean to shim it ?
Old Sep 29, 2008 | 10:51 AM
Rising Phoenix's Avatar
It's just a thin piece of metal that goes between the starter and the engine, all you do is loosen and take out the outer bolt (the one to the passenger side), and loosen (but don't completely remove) the other one. Then you slide the shim in. One end is forked so that it will go around the bolt you left in, then just put the other bolt back in and tighten them both down. Easy!
Old Sep 29, 2008 | 11:24 AM
Z28SORR's Avatar
The proper way is to actually measure the gap between the starter gear and the flywheel(flexplate) gear using a "wire" gage. However you can tell by feel if you've done enough of them.
Old Sep 29, 2008 | 12:14 PM
ulakovic22's Avatar
^^^ is correct, but I've never done it with the transmission attached so I don't know how to do that in car. If the motor is on a stand it's easy.
Formula Steve
Sep 19, 2023 08:31 AM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
