How do u put the belt back on the crankshaft?????
Old Oct 27, 2007 | 08:34 PM
sabedra211's Avatar
Hey I cant put the belt back on the crankshaft wheel. its too tight i tried crow bars and such but its still No luck? Is ther a proper way to do it?? And whats the easiest way to put in a spark plug into cylinder number 7??? Thanks!!!
Old Oct 27, 2007 | 08:56 PM
camarozz95's Avatar
theres a belt tensioner you put a socket on and twist, this give the belt slack to get it on, then you release it. Its under the car to the left of the crankwheel, it pretty small in size.
Old Oct 27, 2007 | 09:16 PM
dangalla's Avatar
the help of another person is very good
you go under the car and turn the tensioner and have someone put the belt on the alt.
Old Oct 27, 2007 | 09:54 PM
WS6T3RROR's Avatar
I usually thread it down from the top and get it on everything but the tensioner, then i pull the tensioner out of the way and slip it into place.
Old Oct 27, 2007 | 09:58 PM
I leave the crank pulley as last. A pull on the tensioner and it's easy to slip over the crank pulley.
Old Oct 27, 2007 | 10:42 PM
sabedra211's Avatar
Hey everyone thanks for the replies! i got it. I put the band thru all of them but the crank tensioner and then i turned it. how about that7th cylinder now?? I got all the new spark plugs and wires in exept for number 7. I took off the old spark plug and now i cant find the hole ?? Any ideas? Thank you
Old Oct 27, 2007 | 11:04 PM
Dave1980's Avatar
this is the way I do it. It is the easiest to do by yourself.
Old Oct 28, 2007 | 08:14 AM
ChevalierSS's Avatar
this is a pretty easy job by yourself. Jack the car up, drop the belt in from the top and route around the altenator. Climb under car and route the rest of the pullies. put a socket on the tensioner to ease tension and slip everything in place.
I replace by tension and belt not too long ago, it took longer to jack the car up/down and find the right wrench than it did to replace the parts.
97SSdude
Dec 31, 2014 07:43 PM
Snoman73
Nov 17, 2014 07:22 PM
1LEThumper
Jul 14, 2003 12:45 PM
Brent94Z
Mar 21, 2002 04:44 PM
