How do u put the belt back on the crankshaft?????
Hey I cant put the belt back on the crankshaft wheel. its too tight i tried crow bars and such but its still No luck? Is ther a proper way to do it?? And whats the easiest way to put in a spark plug into cylinder number 7??? Thanks!!!
Hey everyone thanks for the replies! i got it. I put the band thru all of them but the crank tensioner and then i turned it. how about that7th cylinder now?? I got all the new spark plugs and wires in exept for number 7. I took off the old spark plug and now i cant find the hole
?? Any ideas? Thank you
this is a pretty easy job by yourself. Jack the car up, drop the belt in from the top and route around the altenator. Climb under car and route the rest of the pullies. put a socket on the tensioner to ease tension and slip everything in place.
I replace by tension and belt not too long ago, it took longer to jack the car up/down and find the right wrench than it did to replace the parts.
1LEThumper
Jul 14, 2003 12:45 PM
