How do u get the coil out of its bracket??
Old Jul 15, 2003 | 04:44 PM
speed76demon's Avatar
Arrow How do u get the coil out of its bracket??
just like it says i got it off the car but its in that bracket how to u get it off the bolts that hold it on look like a circle man im so tired give me some help please
Old Jul 15, 2003 | 04:47 PM
They are rivets.
Old Jul 15, 2003 | 04:49 PM
PatriotTA's Avatar
I used a die grinder to grind off the rivet heads on the bottom (looking at it as if it was on the car). Then punched them out with a nail and hammer (I don't have a punch/chisel set yet).
Old Jul 15, 2003 | 04:52 PM
i also broke 2 wires that were in between the two nuts one was a gold braided one the other was black can i just screw them underneath the bolt when i put the coil back on?
Old Jul 15, 2003 | 05:02 PM
Do whatever you can to put the grounds back on.
Old Jul 15, 2003 | 05:04 PM
Kuma's Avatar
Don't forget to put silicon dielectric grease on both the head and the coil bracket when you put it back on (did this myself )
Old Jul 15, 2003 | 06:32 PM
what if i already got it put on and didnt use the grease??
Old Jul 15, 2003 | 06:34 PM
bad95z28's Avatar
i wouldn't worry a lot if you didn't put the grease on.
Old Jul 15, 2003 | 06:35 PM
95_RipperZ's Avatar
I drilled the rivets out for mine.
Fastbird93
Apr 9, 2016 07:01 PM
maybe2fast
Mar 16, 2015 09:45 AM
maybe2fast
Feb 5, 2015 05:14 AM
Lt1son
Dec 22, 2014 10:58 AM
