How do the taillights come off?
Old Jun 14, 2004 | 05:50 PM
Detroit808's Avatar
I need to replace the brake light bulbs in my 94Z. I unscrewed the wingnut inside the trunk, but it doesn't come off easily, and I don't want to break anything. Is there something besides the 1 wingnut to take off, or is there a certain motion involved?
Old Jun 14, 2004 | 05:57 PM
crAzy95z28's Avatar
you dont have to take off the brake lights to get the bulbs out....just remove the rear carpet and there are these black ***** you turn and pull and the light bulb comes out...thats it...but you need to remove the carpet i belive...i remember doing this because i have parted out my other camaro....
let me know if im wrong but if i am im sorry....
randy
Old Jun 14, 2004 | 06:14 PM
Detroit808's Avatar
On mine, I pulled away the carpet, there's 1 black wingnut on each side that I took off, which exposes a screw that's connected to the taillights. That's the only thing that comes through to the inside of the car, so I pulled away at 1 of the lights, and it comes out partway, but the outside end is still held on by something. Is this just a clip I can pull at?
Old Jun 14, 2004 | 06:38 PM
JDBlaze85's Avatar
no clip. just wingnuts hold the lights. just keep looking around, there should be 1 more around the area where it does not want to pull.
Old Jun 14, 2004 | 06:40 PM
lt1maro's Avatar
the last nut is all the way in the corner you have to dig to get to it
Old Jun 14, 2004 | 07:03 PM
Detroit808's Avatar
Thanks for the info. You folks were right...that last wingnut was hiding from me way in the corners! Problem solved.
cardemo16
Aug 24, 2015 01:04 AM
karguy16
Mar 6, 2015 01:31 AM
BlackSixSpeed
Jan 7, 2003 07:19 PM
MysticTeal 95 V6
Nov 15, 2002 02:21 PM
ryan75
3rd Gen / L98 Engine Tech
Oct 22, 2002 08:18 PM
