How do i use dielectric grease, and should i?
Old Sep 19, 2004 | 12:16 AM
pHEnomIC's Avatar
I threw in ngk-tr55 plugs today and want to put in my taylor wires tomorrow that came with some dielectric grease. I was wondering what am i supposed to do with it? I hear you put it in the boot but where do you put it? Do you put it where the plug and wire contact each other? or just a little on the rubber part? I am wondering if i should use it at all?
Old Sep 19, 2004 | 12:56 AM
1racerdude's Avatar
Re: How do i use dielectric grease, and should i?
Take a Q Tip and put a small amount in the plug end boot and metal connector,do the same on opti end.Your boots will come off the next time you change the plugs without having to pry them off.
Old Sep 19, 2004 | 01:04 AM
pHEnomIC's Avatar
So, it is supposed to cover the contact up?
Old Sep 19, 2004 | 07:38 AM
It is supposed to go on the inside of the boot on the rubber.
Old Sep 19, 2004 | 09:13 AM
sabre81's Avatar
actually i do believe my shop manual says to NOT put the grease on the opti side. Only on the plug side
Old Sep 19, 2004 | 05:23 PM
Mtrhds94Z's Avatar
I'd say coat both ends, the inside of the rubber boots only, and not the metal contacts.. [never heard of that 'not on the opti side]
Old Sep 19, 2004 | 11:38 PM
blwnlt4's Avatar
yeah just squirt some on the inside of the boot, its not going to hurt anything, it will even out when you stick it onto the plug
Old Sep 21, 2004 | 11:24 AM
"White Knight"'s Avatar
I never use that stuff. I see no point at least with how and where i drive my car.
Old Sep 21, 2004 | 01:34 PM
It doesn't matter how and where you drive your car. The grease helps keep the boots from sticking to the plugs. You can get the wires off more easily and you don't tear them up doing it.
Old Sep 21, 2004 | 03:48 PM
Fast Caddie's Avatar
FWIW i put about a peanut-sized amount in the end of each boot. That way when you slip it on it seals the boot and connections... even at the opti. Been running like a champ for the last 40,000+ miles and the boots pop off without a hassle.
Old Sep 21, 2004 | 04:40 PM
1 Nasty Bird's Avatar
ya i always do about a peanut size or even a lil more in each end of the wire and just stick it on. Works fine everytie ive done it. Probably 10-15 times now with all teh cars ive owned.
Old Sep 21, 2004 | 06:37 PM
Mtrhds94Z's Avatar
I swab with a Q tip inside the rubber boots only.. nowhere near 'peanut size'..
30th Anniv Z28
Aug 1, 2015 10:39 AM
GetaZforgetGT
May 10, 2003 07:09 PM
96z
Apr 22, 2003 11:39 AM
scoobysnax83
Apr 2, 2003 10:43 PM
Ray66
Nov 7, 2002 09:01 PM
