How do I revove or bypass the EVAP cannister.
Old Dec 18, 2006 | 07:57 AM
  #16
wrd1972's Avatar
Originally Posted by Dave89IROC
well, the old one lasted for 10+ years, think about it...........
Actually no, it has been plugged for at least 4 years, I now know this caused excess fuel tank pressure buildup problem. When the cap was removed a huge blast of wind would almost knock you down.
Originally Posted by Injuneer
Carbon particles in the EVAP solenoid is a fairly common problem. The charcoal does break down. But its not going to hurt anything, other than plug the line or the solenoid. If you're really worried about it (I wouldn't be), put a filter in the line. You probably get more carbon left in the heads from the combustion.
I just hate the thought of possibly contaminating a brand new engine as the result of a known failure.
What kind of filter would do the trick on the line?
Old Dec 18, 2006 | 12:08 PM
  #17
Colin91Z's Avatar
Originally Posted by Javier97Z28
Personally I want to get rid of all that **** b/c it looks terrible under the hood.
I agree. Is there anyway to remove it and not have a fuel odor problem?
If there is, then I'll go for it. If not, I guess I just have to live with a little clutter under the hood
Old Dec 18, 2006 | 12:22 PM
  #18
wrd1972's Avatar
The odor must be a very subjective thing, some say its bad and others say its no big deal.
Old Dec 19, 2006 | 06:01 PM
  #19
Colin91Z's Avatar
I'd rather not have any odor at all. I wish I knew how to eliminate that stuff without that penalty
Old Dec 19, 2006 | 07:55 PM
  #20
matLT1's Avatar
It is very subjective because I removed my evap and have never noticed the smell unless my face is really close to the filler cap. I guess some poeple think they are driving a Cadillac
Old Dec 22, 2006 | 01:48 AM
  #21
TransAm396's Avatar
Old Dec 22, 2006 | 01:50 AM
  #22
TransAm396's Avatar
the white thing is a fresh air vent, but it only allows air IN, not out, if you cap the line you disconnect, you will take a while to fill the tank at the pump............
cant you just remove that white "check valve" to allow air to move both in and out of the tank?
Old Dec 22, 2006 | 02:40 AM
  #23
wrd1972's Avatar
Anyone
Old Dec 22, 2006 | 10:13 AM
  #24
TransAm396's Avatar
I guess ill be a test dummy..ill put a small breath on the end of it and try it...but dont hold your breath, i wont be driving the car till mid may.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
