How do i remove the instrument cluster on my 95 TA fora white face gauge install???
where are the bolts? what do i need to take off? also can i move the needles and will the return to the correct positions? this is an overlay kit. all help would be great
It's not very much fun...
But anyway, the screws are all around the outside, you have to remove the bottom paneling to access some of them, and the rest are underneath the dash pad. Just keep working your way down until you can take the cluster out. Then you can take off the clear plastic and do your business. Be careful with the needles. All of mine seem to work accurately but the temp gauge is slightly off. It's at about 220* at 3/4 now (verified with scanning)- I moved the speedo and tach around when I was working in that area and they're just fine though.
slothgrant
Aug 22, 2002 03:01 PM
