Harness lead at 6 speed ?
Old Feb 17, 2008 | 08:20 PM
palehorse77's Avatar
I've put the motor back in the car and there is a foil wrapped lead above the tranny I can't seem to find a home for??
Comes off the harness just about where the tranny hits the motor on the driver side?
Any input whould be helpful!
Kirk
Old Feb 17, 2008 | 09:10 PM
FlamingChicken's Avatar
just stabbing in the dark but maybe reverse lights? i think the low oil sensor wire is wrapped too. maybe someone knows for sure
Old Feb 17, 2008 | 10:24 PM
greenmachinedriver's Avatar
im gussing low oil sensor, i know it is wraped in foil. runs near oil cooler colant lines.
Old Feb 17, 2008 | 11:40 PM
Thumbs up
Damn! You guys are good!!
It is the low oil sensor. Totally spaced that one.
Thanks so much!
Damn near ready to fire this sucker up! Sounds like you want to let it completely warm before you put load on it. So I figure I need to bleed entire brake system, fill/bleed power steering, bleed coolant before I hit the country roads and do some blasting.
Thanks AGAIN@@!!
Kirk
Alex Barnes
Jan 24, 2015 10:21 PM
mark0006
Dec 25, 2014 09:50 PM
siguy
Nov 27, 2014 10:07 AM
$hawn
Aug 3, 2002 04:59 AM
