How do i hook the computer up to the engine???
Old Apr 15, 2003 | 11:54 AM
Black6SpdTA's Avatar
Question How do i hook the computer up to the engine???
the LT1 im gettin (from a roadmaster), well its comin with a different computer (from different roadmaster). will it be a simple plug in?
Old Apr 15, 2003 | 01:06 PM
Gripenfelter's Avatar
Yes it should be fine.
LT1 from one Roadmaster and PCM from another Roadmaster.
Old Apr 15, 2003 | 03:00 PM
what im asking though is is it going to be hard to actually hook the computer up to the engine? how do the two connect?
Old Apr 15, 2003 | 03:05 PM
You need A) the PCM, B) the engine, and C) the wiring harness. Do you have all three? Connect all the harness connectors to the appropriate points... there are 4 large connectors on the PCM, and a myriad of connections to the engine and dashboard. Do you have a wiring diagram for the Roadmaster? That would help you sort out which wire/connector goes where.
Old Apr 15, 2003 | 03:10 PM
thanks fred, ill find a wiring diagram somewhere.
Old Apr 15, 2003 | 03:52 PM
Dr.Mudge's Avatar
Wiring stuff IMO is the worst part about an engine swap, but it will teach you ALOT about the sensors (when you pin things out to check for problems), and the setup in general.
Factory service manual, or even something with wiring diagrams would be worth its weight in gold. Expect some downtime because wiring is not a 1 day job, unless you've done it before.
mr28
Apr 20, 2016 05:44 PM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
Jan 5, 2015 07:14 PM
Injuneer
Dec 15, 2014 09:36 AM
Absolute Z28
Jul 19, 2002 02:21 PM
