How to disconnect this battery? PICS!
Old Jun 16, 2003 | 10:01 PM
dak125's Avatar
Hey guys, I figured since everyone was so helpful with my last problem with the stat, this would be a piece of cake. I want to try Brent's way of eliminating skip shift (any opinions?) and it calls for disconnecting the battery. Here are some pics of my battery, how do I go about disconnecting it? I went out and bought a proper tool set tonight I'm ready to go.
Pic 1:
http://www.dakology.com/images/battery%201.JPG
Pic 2:
Pic 3:
http://www.dakology.com/images/battery%203.JPG
Pic 4:
Thanks-DaK
Old Jun 16, 2003 | 10:07 PM
Kris93/95Z28's Avatar
Use a 5/16" Wrench.
Use a 5/16" boxed end wrench (better if it is a 6 point) and remove the negative battery cable. That's all.
dak125's Avatar
Originally posted by Kris93/95Z28
Use a 5/16" Wrench.
On what? . I'm rather new at this...
Old Jun 16, 2003 | 10:09 PM
On the black side terminal (nearest the fender) on the battery.
Old Jun 16, 2003 | 10:10 PM
dak125's Avatar
Awesome, thanks.
The little 5/16" terminals that are screwed in the battery. There is one that is surrounded by BLACK , and the other is surrounded by RED.
Old Jun 16, 2003 | 10:14 PM
BTW Dak I checked your site, your car is BEAUTIFUL. I have always loved the Blue 4th gens, they are probably my favorite color. Ver y Nice
Old Jun 16, 2003 | 10:30 PM
dak125's Avatar
Thanks Kris! Hey guys, bit of a problem. There is no GRAY wire as listed in Brent's guide to disable the skip shift. There is a white wire and I removed it successfully, but there't nothing in slot 13 at all. What should I do?
Old Jun 17, 2003 | 12:01 AM
Laymaster's Avatar
I use a 1/4" drive 8mm socket wrench...I think the 3/8" drive wrench will fit in there too, or at least it will on the positive side.
Old Jun 17, 2003 | 12:11 AM
PoorMan's Avatar
I just had to click on this post to see if it was for real. I guess it is. Good luck with the skip shift mod.
Jeff D.
Old Jun 17, 2003 | 01:08 AM
dak125's Avatar
Hey, I'm just glad I asked. I would much rather look like a dumbass over the internet then turning into a very crispy and fried version of myself . All's well now, skip shift works flawlessly.
Old Jun 17, 2003 | 01:11 AM
NiteRider's Avatar
Might be cramped for a wrench in there, try vice grips and if you do use a wrench make sure the back of the wrench dosen't touch the a/c or else sparks will be flying, lol...
Old Jun 17, 2003 | 07:41 AM
You always remove the negative. Unless you touch the positive post, no sparks will fly. Why would you want to ruin the head of the bolt with vise-grips? They are lots bigger than a wrench anyway.
Old Jun 17, 2003 | 07:48 AM
94BlackBowtie's Avatar
You're car is beautiful, I absolutely love that color - even though it isn't black.
"Little Boys Wear Bowties, Little Girls Ride Ponies."
