How to disassemble rods from pistons ---
Old Oct 27, 2006 | 05:43 PM
AlwaysCode390's Avatar
Question How to disassemble rods from pistons ---
I got a set of pistons with the i beam rods pre-installed....well I am upgrading to the eagle h-beams and would like to sell the i-beams to free up some $$$. Do I just take off the side clips near the wrist pins? Any special tools needed....can they be reused (everything is new)? Thanks ---
Old Oct 27, 2006 | 05:51 PM
ajlew9428's Avatar
are they full floating? If so, then just take the pins out, and pin should fall out. If they are pressed, youll have to take it to a machine shop to have them removed
Old Oct 27, 2006 | 06:01 PM
DAMN, they are pressed ---
Now would be a good time for me to figure out what the difference is between bronze bushed vs pressed (luckily my h beams are bushed, is that normally considered "better"?) ,thanks ---
Old Oct 27, 2006 | 06:18 PM
ajlew9428's Avatar
bushed means the wrist pin will rotate inside the rod,( full floating)and are held in by a clip, pressed are pressed, or wedged inside the rod. If you are going high rpm, bronze bushed is the way to go. Its used on high performance engines. I think most h beams, if not all, are bronze bushed
Old Oct 27, 2006 | 07:02 PM
oneslowz28's Avatar
what you selling the i beams for? pm me a price
Old Oct 27, 2006 | 08:21 PM
rskrause's Avatar
Moderator
It requires some experience (as well as a press) to get pressed pins out without damaging the pistons.
Rich
Old Oct 27, 2006 | 08:28 PM
oneslowz28's Avatar
but any good machine shop can do it.
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
