How difficult to replce rear caliper?
Old Aug 18, 2003 | 07:52 PM
caliking97's Avatar
Just wanted to ask the pros how difficult it was to chang the rear brake caliper. Thanx in advance
Old Aug 19, 2003 | 06:38 AM
revtime's Avatar
Not bad at all.
Once u get the wheel off you will see what needs to be done.
Probably the hardest thing you will run into will be getting the brake line off and bleeding the brakes.
Not that hard though, get a friend to help with the brake bleeding and you should be good.
Old Aug 19, 2003 | 07:16 AM
96CamZ's Avatar
I just did this and it isn't bad. Like revtime said the hardest part is bleeding the brakes right. There is a bracket on the caliper that you will need to take off, before you take it in for the core. Autozone didn't include this when I did my rear calipers.
carguy0119
Apr 11, 2016 11:11 PM
Alien
Jun 27, 2015 01:13 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
FirebirdGT
Dec 13, 2014 10:25 PM
