How to clean EGR, and will it last?
I was wondering if anyone had any tips on cleaning the EGR- I know where it is so I can pull it off, should I just use some carb cleaner on it or something? Ive heard stories of this causing problems with the seals so should I just replace the whole thing? Also Im guessing I need to put some sealant on before I put it back on? What kind? Or is there a gasket?
-P.J
-P.J
Do whatever you need to do to clean the valve off and make sure that it moves freely in and out. You can also scrape any carbon out of the holes on the back of the manifold. You might need to use a mirror to see the back of the manifold. There is a gasket that goes on it.
sleeperZ96BT
Sep 9, 2015 08:28 AM
