how to check timing?
Old Apr 9, 2003 | 09:07 AM
qwick_trip's Avatar
ok just like it says i want to check my timing to see where it's at how do i do that??
Old Apr 9, 2003 | 01:16 PM
Timing is set by the PCM. If you hook up a scanner, it will show you the advance the PCM is trying to set. It does not tell you the actual timing, but since the Opti is feeding the cam and crank position to the PCM, its probably correct.
The only way to use a timing light would be to mark TDC on the damper, and add a degree marker to it.
jb4xx
Feb 2, 2015 10:00 PM
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
danielbmx
Aug 27, 2002 11:11 PM
