Still maxing out injectors
Old Apr 9, 2003 | 09:42 AM
Highlander's Avatar
I installed today the 50lbers and I am still maxing them out...
At least datamaster shows 104% duty cycle...
Any thoughts????
I also have a superfueler with 2 96 and one 83.
At least now I can rev to 6000 as opposed to 5400 with the 30lbers. I am running 50psi FP at idle and above 60 at WOT...
Old Apr 9, 2003 | 09:43 AM
mongse_1's Avatar
That can't be right. What kind of combo do you have? Did you get the injectors flow tested/cleaned before installing them?
Old Apr 9, 2003 | 09:47 AM
Gripenfelter's Avatar
Something is screwy there.
50lb injectors should be fine.
Someone here should be able to take a look at your log.
I'm illiterate when it comes to that though.
Old Apr 9, 2003 | 09:49 AM
Highlander's Avatar
I can send it.. I have a supercharger and I am doing between 495-520rwhp...
I have a superfueler also with 2 92 lbers and 1 83 for the moment.
Something is wrong here...
Old Apr 9, 2003 | 01:01 PM
You said you had the injector constant set at 42#, even though they are high-Z 50's. Do you still have the constant set at 42#? That would explain why you are getting 104% duty cycle... the calculations aren't correct.
It almost sounds like the "50's" aren't really 50's. Are you sure the stock PCM supports injector constants that high?
Old Apr 9, 2003 | 01:41 PM
Highlander's Avatar
I fixed that they needed bigger offsets.. I have them set at 52# due to the fact that the fuel press is set at 55psi - 70psi at WOT...
It maybe my calibration or WOT Table since I had them set for 30# and there is a big spike
4.7
4.7
1.2
1.2
1.2
3.9
3.9
-5.5
-7.8
-7.8
-4.3
-5.5
15.6 5200
41.4 5600
46.5 6000
48.4 6400
49.6 6800
As soon as I got to 5400 my fuel curve began to spike up and I thought it was because I totally maxed the injectors...
Now I still have that spike and it will jump from 70% to 97 and 105%... but my O2 millivolts are the same, although I know they are far from accurate in the upper and lower ranges...
Any suggestions?
93 RedBird
Nov 15, 2015 08:24 AM
form94
Sep 23, 2015 07:30 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
