how to check iac and tps
Old Mar 26, 2008 | 07:11 PM
jwhk2001's Avatar
ok I am going to get a tune from the mail but I dont know how to check my tps and iac to make sure they are set correctly, any ideas?
Old Mar 26, 2008 | 07:19 PM
Your going to need a scanner to look at the IAC. The TPS can be checked with a meter, but a scanner can more easily look at the readings.
Old Mar 26, 2008 | 07:25 PM
jwhk2001's Avatar
I have a scanner available but what are my specs supposed to be on the scanner?
Old Mar 26, 2008 | 07:30 PM
Here is a good reference.
Old Mar 26, 2008 | 07:39 PM
jwhk2001's Avatar
thank you I will set my car to these specs and see what happens
Old Mar 26, 2008 | 08:55 PM
Wild1's Avatar
What scanner is the best out there now for LT1s? In an ideal world with money being no object.
Old Mar 27, 2008 | 02:03 AM
ss.slp.ls1's Avatar
Autotap with GM enhanced parameters.
Old Mar 27, 2008 | 07:30 AM
Depends on the year of the PCM. Autotap is only for OBD-II (96/97). OP has a 94, which is OBD-I (93-95). "Wild1" hasn't told us what year his car is, so we can't acurately answer his question. For OBD-I, there are Auto Xray OBD-I scanners that are available fairly cheap, used, on eBay. Make sure its a "real" scanner, and not something like the $30 Actron "code reader", which is simply a device to short the ALDL pins, and only works on a 93.
The absolute best scan tool, money no object, would be the OTC Tech-2 that the GM service techs use, which lists for $9,000 and can be had for about 1/2 that cost new, and less used.
http://www.denlorstools.com/home/dt1...scan_tool.html
For OBD-I scanning software (just in case you are not a billionaire ):
TTS DataMaster:
http://www.ttspowersystems.com/
FreeScan:
http://www.andywhittaker.com/
Cables:
http://www.akmcables.com/
Old Mar 27, 2008 | 11:29 AM
Wild1's Avatar
Sorry, I've got a '95 Z28. I've wanted to check my IAC and TPS too with the new TB and Dyno Tune. Can you provide a link to OP?
I should start a new thread, if this is a steal I am sorry.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
