How to cheat emmissions 101! It worked!
Old Nov 24, 2003 | 06:58 PM
  #16
RCF925's Avatar
One reason I put a Blower on mine is cause it helps pass smog
My old 355 wouldn't pass without the Blower.
Old Nov 24, 2003 | 09:04 PM
  #17
Z28ROC's Avatar
Way to go man! Glad it worked out for you guys.
Also wondering if rigging the air pump to stay on would help pass smog.
Old Nov 24, 2003 | 10:00 PM
  #18
6Speed's Avatar
I have a question about unhooking the injectors. If you unhook 2 injectors, shouldn't you disconnect those sparkplugs as well? I mean, if there is still spark going to those cylinders, but no fuel, will that not have a bad effect?
Old Nov 24, 2003 | 11:48 PM
  #19
No. The AIR pump adds the air before the O2 sensors. The sensors would see the extra "air" and start adding extra fuel that the engine doesn't need.
If there is only air in the combustion chamber, and no fuel, there will be no combustion. You might generate a trace of ozone from the high voltage discharge of the plug, but that's not an emissions issue.
Old Nov 25, 2003 | 07:38 PM
  #20
TW95Z's Avatar
Originally posted by Procharger
here the trick i did after failing 10 times. tryed timing/vacumhoses/denatured alchol/even put my stock injectors in.. still failed..So i thought about it for a sec.. let me try something stupid.. i un hooked 2 injectors and let it run on 6 cylinders.. guess what passed with flying colors.. after i got the paper in my hand pulled the car out of the bay and hooked up the 2 injectors and laughed my a$$ off.. the next year they stopped doing emission testing in our county..
Which 2 injectors?
Old Nov 26, 2003 | 09:03 AM
  #21
IslandZ's Avatar
emission testing?? What is that :-)
Living on an island has its benefits
Old Nov 26, 2003 | 11:33 AM
  #22
gb95zconv's Avatar
Re: How to cheat emissions 101! It worked!
Originally posted by chevy5143
My uncle and his hot rod buddies told us to hook up a compressed air tank and tape it into the exhaust before the cat/sniffer(duh) rig a switch connected to petal, then open up the tank and hope. They said the compressed O2 will change the mixture of expelled exhaust and flush out.
I helped my brother do the same thing using the AIR. Just routed some plumbing to just after the cat and rigged up a switch. BTW ...he had allready done the !AIR....we just put it back in the stock location and rigged the rest....worked like a charm.
Old Nov 26, 2003 | 12:42 PM
  #23
Larnach's Avatar
But what if you ran a switch in your car, and ran the lines to a tapped thread or something just before the cat... therefore always injecting air into the system after the O2's... what kinda volume of air is released from that air pump?
Old Nov 26, 2003 | 01:22 PM
  #24
notstock4long's Avatar
I don't think that little air pump would really push enough air to do that. It might be able to, but I don't think it has the *****.
Old Nov 26, 2003 | 02:03 PM
  #25
96z's Avatar
96z
Nice thinking.
Old Nov 26, 2003 | 04:01 PM
  #26
bunker's Avatar
You would have to disconnect atleast one of your oxygen sensors to run in open loop & then disconnect 2 injectors otherwise the others will be running really rich since the o2's will make the computer compensate, disconnect one o2 & you're running open loop.
Old Nov 26, 2003 | 06:27 PM
  #27
Geezer powered's Avatar
how did you tape a hose inside your exhaust pipe? and where did you put the tank. No body saw or heard the tank pumping out fresh o2. not calling bs but just ?'s
Old Nov 26, 2003 | 06:47 PM
  #28
Johnnynsac's Avatar
This is the best class I've ever taken and it's free. Thanks guys
Now what would happen if you were to get caught? hmm
Old Nov 27, 2003 | 12:14 PM
  #29
chevy5143's Avatar
We didn't "tape" the hose to the pipe. Like i mentioned before you use a connection piece from an air compressor and tack weld it into the pipe before the cat. Check the post at the beginning of the thread it has a link that will help answer some more questions.
[QUOTE]Originally posted by Geezer powered
how did you tape a hose inside your exhaust pipe? and where did you put the tank. No body saw or heard the tank pumping out fresh o2. not calling bs but just ?'s [/QUOTE
Old Nov 27, 2003 | 12:27 PM
  #30
you guys are sneaky sneaky lol that is a great one.
