How can you tell if you have a spun bearing?
Old Sep 11, 2003 | 12:27 PM
  #16
thewinner's Avatar
Originally posted by Patman
What causes a spun bearing anyways?
lack of oil
Old Sep 11, 2003 | 07:03 PM
  #17
Patman's Avatar
Originally posted by thewinner
lack of oil
So if an oil pump were to fail on you while you were going full throttle, would that cause a spun bearing pretty much instantly then?
Old Sep 11, 2003 | 08:54 PM
  #18
TreySpeed's Avatar
On permanent vacation
it can. a spun bearing is when the main bearing "spins"
when the crank puts too much force on them it will spin. oil reduced the friction between the bearing and crank.
high rpms- more Rpms = more "force" on it. when that bearing spins- the end is near.
Old Sep 12, 2003 | 05:17 AM
  #19
Patman's Avatar
So if I leave my engine close to stock, and keep the stock 5700rpm shift points, my chances of a spun bearing in the future are pretty low then, correct?
Old Sep 12, 2003 | 05:20 PM
  #20
notstock4long's Avatar
When I spun my #1 bearing, the bearing halves were actually both sitting on the bottom of the rod on top of each other. So whenever that cylinder fired, it would know because of the rod getting pulled up and slapping the crank. Mine was also non existant when it was cold, but when it warmed up it was damn loud. And it happened the only time, and I mean only, that I reved it past 4.5k.
Old Sep 12, 2003 | 06:13 PM
  #21
TreySpeed's Avatar
the further the gap gets b/t the bearing and crank/rod -whatever for that matter- the greater your chances of spinning a bearing
since you aren't going to add material to the bearing this pretty much translate to the more worn the bearing the greater the chances of spinning it. Only time it would get too tight is an imporpper (re)build.
I honestly wouldn't lose sleep over spinning to 6400
Old Sep 12, 2003 | 06:42 PM
  #22
RCF925's Avatar
If your motor is in good shape over revving won't spin a bearing, Lack of oil or Oil pressure will or too close tolerances or getting any coolant in the oil such as a head gasket going, Main bearings will be a different kind of knock than rod bearings, Rod bearings you hear on every stroke, Mains aren't quite so loud and you may hear more on start-up but if you keep driving the car they just get worse intil something breaks.
Old Sep 12, 2003 | 09:14 PM
  #23
TreySpeed's Avatar
the tighter the tolererance, the better.
You are confusing the words clearance and tolerance
Old Sep 12, 2003 | 09:24 PM
  #24
RCF925's Avatar
Clearance, Thats the word I was looking for
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
jackpawt883
Sep 10, 2015 08:53 PM
