Switch for Convertible Top Broken?
Old Sep 12, 2003 | 08:54 PM
z28jaz's Avatar
I think the switch for my top may be broken. When I try to put the top down, nothing happens most of the time. Occassionally it will work after holding the switch for a long period of time. Going up however works fine. Anyone had a similar issue with any input? Would it be possible for just part of the hydraulics to not work?
Also, does anone have the part number for the switch?
Thanks in advance guys.
Old Sep 12, 2003 | 09:31 PM
TonyJ's Avatar
You probably need to bleed the system. Here're the directions:
Subject:
Folding Top Hydraulic System
Models:
1994-2OOO Chevrolet Camaro
1994-2OOO Pontiac Firebird
This bulletin provides information regarding adding fluid to the folding top hydraulic system as well as bleeding this system.
Adding Fluid to Folding Top
1. Place the vehicle on a level surface.
2. Lower the folding top.
3. Remove the left side trim panel from the rear compartment.
4. Place a shop towel around the pump/motor in order to control oil spillage.
5. Remove the reservoir filler plug.
6. Add DEXRON(R) III Automatic Transmission Fluid (U.S. P/N 12378470, Canadian P/N 10952622) until the level is between the upper and the lower reservoir indicator lines.
7. Install the reservoir filler plug.
8. Cycle the folding top up and down several times.
9. Inspect the fluid when the top is in the down position and add fluid if necessary.
10. Install the left side trim panel to the rear compartment.
Folding Top (Bleeding System)
Notice: When servicing the hydraulic system, follow these precautions:
^ Leave the folding top raised but unlatched from the windshield header. This will keep the cylinder rods extended and minimize fluid leakage.
^ Do not allow the oil to drop below the lower indicator line on the reservoir or pump damage will occur.
^ In order to avoid pump damage during the bleeding procedure, verify that the cylinder rod does not touch any body components or the folding top when extending.
1. Open the rear compartment lid and remove the trim from the left and right side.
2. Remove the left and the right side interior trim panels in order to gain access to the cylinders.
3. Remove the cylinders from the outer arms (1).
4. Remove the cylinders from the main pivot brackets (2).
5. Position the cylinder so that the cylinder rods (3) will not touch any components or the folding top when fully extended.
6. Remove the reservoir filler plug.
7. Remove the one pink hose (4) from the pump motor and place the hose in the reservoir opening.
Important: Seal the fitting to prevent air from entering the system. Use a rubber plug such as a snug fitting vacuum fitting cap. Seal the open pump fitting.
8. Remove one pink hose (4) from the pump motor and place the hose at the reservoir opening.
9. Push and hold the up button on the convertible top switch. After the cylinders are fully extended, continue to press the switch until the hose being bled is free of air bubbles.
10. Install the pink hose (4) and tighten.
Tighten
Tighten the hose to 7 N.m (62 lb in).
11. If the fluid level is low, add DEXRONŽ Ill Automatic Transmission Fluid (U.S. P/N 12378470, Canadian P/N 10952622) to the reservoir.
12. Repeat the bleed procedure for the other cylinder.
13. Install the reservoir filler plug.
14. Install the interior trim panel to the rear compartment.
15. Rotate the pump bypass valve fully clockwise (1/4 turn) to the open position.
16. Install the cylinder to the outer arm.
17. Install the cylinder to the main pivot bracket.
18. Rotate the pump bypass valve fully counter clockwise (1/4 turn) to the open position.
19. Install the cylinders to the outer arms.
20. Install the cylinders to the main pivot brackets.
21. Install the right and the left interior trim panels.
22. Rotate the pump bypass valve fully counter clockwise (1/4 turn) to the closed position.
23. Cycle the folding top up and down several times in order to verify the hydraulic system operation.
24. Install the right and the left trim panels to the rear compartment.
Parts Information
Part Number Description
U.S. 12378470 DEXRON(R) III
Canadian 10952622
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor
Operation Description Labor Time
B3450 Hydraulic Bleed, 0.5 hr
Folding Top
Here's another good resource:
http://www.chirpthird.com/ubbcgi/ult...?ubb=forum&f=9
WildRidez
Feb 23, 2015 07:24 PM
nosliw
Feb 7, 2015 01:30 PM
joe777107
Dec 1, 2014 09:32 AM
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
