how can you tell if a rod was thrown ?
Old Mar 31, 2010 | 03:22 PM
dallas63's Avatar
Unhappy how can you tell if a rod was thrown ?
my wife was driving our 1996 camaro z28 2day , when it stopped running . there is oil all all over the engine and it wont start . but it will turn over . could this be a thrown rod or something simpler hopefully . any and all help is appreciated . thanks jay ps no pressure just turns over
Old Mar 31, 2010 | 03:36 PM
RamAir95TA's Avatar
What is all over the engine?
What's the oil pressure?
Old Mar 31, 2010 | 03:39 PM
dallas63's Avatar
oil
oil and no pressure .jt turns over
Old Mar 31, 2010 | 03:41 PM
RamAir95TA's Avatar
If there's oil all over everything, then you probably put a rod through the block or oil pan.
Have you physically looked yet?
Old Mar 31, 2010 | 04:15 PM
dallas63's Avatar
i cant get it on the ramps yet to look . but i put oil in it and wasnt leaking . also , got the pressure up to the 1st white line
Old Mar 31, 2010 | 05:26 PM
95Blackhawk's Avatar
Much more details:
where is oil coming from?
What were you doing when it stopped?
Old Mar 31, 2010 | 08:19 PM
craby's Avatar
check and see if the oil pressure sensor is broken or cracked. could have been spraying threw a crack when the oil was hotter and thinner. its back behind the intake maifold on your yr i think. if u lost oil pressure the computer should shut the injectors off and or the fuel pump.
Old Mar 31, 2010 | 10:49 PM
dallas63's Avatar
my wife was in park idling at the atm .
Old Apr 1, 2010 | 05:17 AM
The LT1 in th F-Body does not have the oil pressure/fuel pump interlock, like the LT1 in the Corvette. Low oil pressure will not shut anything down via the PCM.
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
KYWes
Sep 26, 2015 08:49 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
