How can I tell if I have weak valvesprings or valve float
Old Jan 5, 2005 | 03:30 PM
wicked_95z's Avatar
Will weak valve springs look like a high rpm miss on a dyno graph. How else can I check? I am running ex-612 springs from Combo motorsports and I was recently told to go with 977's from Comp. Do the heads have to be machined for 977's? Thanks
Old Jan 6, 2005 | 07:56 AM
wicked_95z's Avatar
Re: How can I tell if I have weak valvesprings or valve float
Anyone?
Old Jan 6, 2005 | 11:41 AM
SS MPSTR's Avatar
Weak springs can show up as a misfire caused by the valve float. And yes, the 977's will require a larger seat.
Old Jan 6, 2005 | 11:49 AM
wicked_95z's Avatar
Old Jan 7, 2005 | 03:07 PM
wicked_95z's Avatar
Is it possible to have a high rpm miss without having a low or mid rpm one? I truns great down low. I can usually tell if I have a miss cause in 6th gear at 1500 rpms is shakes violently. But now its just as smooth as ever until I hit about 5000-5500 rpms.
Old Jan 7, 2005 | 03:22 PM
SS MPSTR's Avatar
Yes.
Old Jan 11, 2005 | 03:46 PM
ravigogna's Avatar
Hood up a vacuum gauge and partial throttle it up the rpm you think its floating at. If you partial throttle it you will have about 20 in of vac, once your valves start to float you will see the gauge bounce around.
If you need help you can give me a call me
Ravi
Speed Freaks Inc - Performance Dyno Shop
209.609.0355
Old Jan 11, 2005 | 04:21 PM
"White Knight"'s Avatar
Where exactly would you tap in that vacum gauage??
Old Jan 11, 2005 | 07:23 PM
LT4orbust's Avatar
i hope the 612's aren't the problem, thats what i have still to go in mine,
Old Jan 12, 2005 | 01:47 AM
ravigogna's Avatar
white night you can tap the line into any vacuum port on the intake manifold, I would unplug the vacuum line going to the optispark. That way you don't set any EGR or EVAP ses lights. Just don't unplug your fuel regulator vacuum line.
Ravi
209.609.0355
Old Jan 12, 2005 | 12:58 PM
turbo_Z's Avatar
Valve float shouldnt look like a simple misfire or spike on the dyno. The curve should suddenly fall off is all. If you think about it.. theres no way to float a valve for just an instant. The problem will start at some rpm and get worse as you keep going so the graph will die off very suddenly and never pick back up again as you find with a misfire. This is all assuming you are floating every single valve using a relatively weak valve spring for the cam. I suppose you could have 1 that is bad causing that 1 valve to float in which case you could have a high RPM misfire with that 1 cylinder.
Old Jan 12, 2005 | 02:26 PM
Kreinmc's Avatar
I also I have the EX612 valve springs with my 1.7 roller rockers and I am having some issues as well. You can look at the graphs on the bottom of the link in my sig. The power drops off like a rock up top. 40-50 hp instantly. I have heard these springs are not so good, so I ordered up the crane 10308 spring kit that I used with my 306 in my last car. I was thinking about ditching the 1.7rr's as well, but I think I will try out the bigger springs first.
POLOVETTE 94
Aug 21, 2015 07:11 PM
350350
14
Aug 11, 2015 12:03 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
94Form
Jul 17, 2015 10:56 PM
