How can I tell the difference between 7/16 and 3/8 studs
Old May 28, 2004 | 02:28 PM
TenaciousZ's Avatar
I honestly feel stupid for asking this, but I have a set of GM 1.6 rockers and I need poly-locks for them, But I don't know if they are 3/8 or 7/16th studs. anybody have pictures of the two?
Old May 28, 2004 | 02:44 PM
Type_O_Negative_1320's Avatar
Are they the GM LT4 rockers (silver with little bowties on the tips)? If so, they're 3/8".
EDIT: If you order a set from Jeg's, get the set that is for a 0.550" wide slot. The 0.600" wide ones won't fit the LT4 rockers.
Old May 28, 2004 | 02:46 PM
TenaciousZ's Avatar
they are silver with the bowtie emblem on em. So the end of the stud that the rocker slips on is thinner than the end that screws into the head? best as I can explain it right now
Old May 28, 2004 | 02:47 PM
Yes, the end that the rocker goes on is thinner. 3/8" and 7/16" refers to the size of the hole in the rocker arm. Stock rocker studs are 3/8".
Old May 28, 2004 | 02:50 PM
TenaciousZ's Avatar
think I got it so i'm just ordering a set of 3/8 poly-locks with a 0.550" wide slot?
Old May 28, 2004 | 02:55 PM
Exactly.
Quickss96
Jan 29, 2016 05:56 PM
bunker
Aug 21, 2015 10:21 AM
whitehooptie
Aug 10, 2015 07:02 AM
4586
Jul 31, 2015 06:03 PM
JCSWS6
Jul 19, 2015 06:47 PM
