how can i run cooler???
Old Jul 14, 2003 | 09:37 PM
jasons93z's Avatar
Its been in the 100's here in oklahoma. I have a 160 stat, manual switch, water wetter and i am still running to hot for my liking . im not overheating. What else can i do? Btw, i have already blead the system.
Old Jul 14, 2003 | 09:39 PM
TMDZ28's Avatar
turn the manual fan switch at high speed?? how hot are you running now??
Old Jul 14, 2003 | 09:42 PM
Red96Lt1's Avatar
Well since you're not concerned about freezing, running 100% water might help, with the water wetter to help prevent rust. Water has a higher heat capacity than antifreeze. So basically it can take away more heat from your engine. This is the only thing that I can think of. Hope it helps.
Old Jul 14, 2003 | 09:43 PM
jasons93z's Avatar
its always on high speed. It runs between the middle mark and redline in the city. This only happens when its real hot(it was 103 today ). But i still dont like it.
Old Jul 14, 2003 | 09:47 PM
gb95zconv's Avatar
Get a better radiator like a Be Cool.
Old Jul 14, 2003 | 09:48 PM
hey01's Avatar
do you have air in the system???
thermo hanging?
a be-cool radiator would do the trick
Old Jul 14, 2003 | 09:50 PM
jasons93z's Avatar
the stat is a powerstat and its new. I dont want to buy a new radiator. Anything else?
Old Jul 14, 2003 | 09:51 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
whats your liking?
no offence, but who cares what you like
65* is too hot for a pengiuns liking
Old Jul 14, 2003 | 09:57 PM
drewstealth's Avatar
You probably have air in your system, from when you installed that stat. I had that problem when i put my new waterpump on. I bled it again and it is all better now. But i'm about to install a 160 stat tomarrow because i want my temp a little lower.
Old Jul 14, 2003 | 09:59 PM
jasons93z's Avatar
Originally posted by treyZ28
whats your liking?
your gonna get a beat down . I have already blead my system. Im
Old Jul 14, 2003 | 10:14 PM
Stock Z's Avatar
I was having a similar problem, running at 210°F when it is 100°F outside with the A/C OFF and would quickly approach 235°F with the A/C on. Looked into a Be-Cool radiator but for $680 bucks for a radiator!! So I simply got a radiator from the nearest autoparts for $200 and now I run at 185°F even with the A/C on and 100°F outside.
94Z28LS1toLT1
Parts Wanted
Jan 21, 2015 04:37 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 12, 2014 10:51 PM
thenewkid
Nov 27, 2014 09:41 AM
Camaro90RS
Jul 23, 2002 07:57 AM
