How can I figure out what size my Aftermarket TB is
Old Mar 30, 2005 | 01:21 AM
TireMarx723's Avatar
Its a RKsport TB but how can I tell if its 52mm or 58mm?
Old Mar 30, 2005 | 02:48 AM
Brent94Z's Avatar
Super Moderator
Re: How can I figure out what size my Aftermarket TB is
You could measure the diameter of the openings 25.4mm/inch if you don't have a mm ruler.
Also, if you have it off look at your intake. Most intake port jobs it is "obvious" they have been ported because normally a Dremel or similar hand held tool is used. The stock openings are 52mm. If yours have been bored larger for the throttle body, chances are it's a 58mm tb. If the intake holes are nice and perfectly round and the tb mates up good then it's likely a 52mm.
However, easiest way by far is to just measure the openings (across the center).
Old Mar 30, 2005 | 10:00 AM
Thanks, so measure each opening separately correct? (aka each circular opening)
Old Mar 30, 2005 | 10:28 AM
Brent94Z's Avatar
Super Moderator
Yep!
Old Mar 30, 2005 | 12:07 PM
DavesLT1's Avatar
t-gage and calipers would be the most accurate, but a tailor's tape should be enough to find out. 48mm~1.89" 52mm~2.05" 58mm~2.28"
HectorM52
Jul 30, 2017 11:46 AM
IgorT.455/406
Mar 12, 2015 03:39 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
smokin25th
Jan 1, 2015 09:06 AM
heavenly_six
Dec 10, 2014 12:23 AM
