How is this cam?
Old Dec 5, 2006 | 04:48 PM
mdacton's Avatar
How is this cam?
dur@ .050 263/271
lift .640/640
separation 106
sollid roller
stock heads, stock short block, want to make this car a bracket car th350 is going in , have 4.57 gears, I have not ordered a converter yet I run the car on motor and I'm 3200#
Would this cam run pretty good?...want to win some races next year
Old Dec 5, 2006 | 05:11 PM
rasputin's Avatar
stock unported heads? looks like you will be choking the hell out of that motor without heads.
Old Dec 5, 2006 | 05:15 PM
dre2013's Avatar
thats exactly what i was going to say. At least do some mild porting on them, otherwise id imagine up top you'd be missing out on quite alot of ponies. Why do you want to keep them unported just wondering?
Old Dec 5, 2006 | 05:20 PM
mdacton's Avatar
just to see what they can do unported.....
Old Dec 5, 2006 | 05:52 PM
snakeatinZ's Avatar
You will waste time and money!!! Find a smaller SR cam, I would bet the smaller cam would be faster at the track. Seeing as how it would work better on the stock heads.
Also the cam listed above would need to see rpms that a stock short block can not reach. 6800 - 7500 rpms
Steve
Old Dec 5, 2006 | 06:42 PM
mdacton's Avatar
i may do a little work to the bottom end and get some good parts in it...that cam was reccomended by a cam company for the stock heads They say if I do any work to the heads I need a bigger one
Old Dec 5, 2006 | 06:58 PM
ABA383's Avatar
That huge cam for stock heads?!! That seems crazy to me...You're right down there in Joe Overton/Eric Bradby country...Use them and go fast...
--Alan
Old Dec 5, 2006 | 07:02 PM
mdacton's Avatar
I got eric doing some heads now, Joe is nowhere to be found
I tried that allready now i'm trying AED
Old Dec 5, 2006 | 08:55 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I would immediately stop talking to whoever told you that would be a good cam for stock heads because they evidently have no idea what they are talking about. That thing will have to rev way too high and stock heads fall on their face flow wise anywhere after 6k in fact before. That is a HUGE cam.
Old Dec 5, 2006 | 09:04 PM
mdacton's Avatar
bullet racing cams.... they were highly recomended locally
Old Dec 6, 2006 | 01:10 AM
edman's Avatar
You have 40 degrees too much duration on both sides.
Did you know that stock LT1 heads don't flow as well as stock Vortec cast iron truck heads? Even a little bit of bowl porting can barely support as much as 236/244 degrees. You are going to loose power across the board. You will max out at 6500rpm, but you might have only 240 to 250 hp at the wheels instead of the 320 to 350 that the cam can wheel up on the right engine. You do mean these specs at the .050" checking clearance, but you would make better power if this was the advertised duration at running clearance.
You might have valve to piston interference too. Be really careful to check for it. If they hit, there are no such heads that will give you clearance, you will need to get your pistons cut for deeper valve reliefs. You can do it with pistons installed, but with the heads coming off, there will then be no reason to reinstall them again. Go with LT4 or aftermarket 185cc minimum.
You were really just playing with us , right??
Old Dec 6, 2006 | 07:05 AM
toby's Avatar
you will need an aftermarket computer to really take advantage of that cam. the factory computer will not let you rev over 7200. so maybe a 255/263 would be better. i would get it with a 108 lsa though that's more ideal for a 350.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
