how to bleed air out of cooling system
Old Jun 28, 2004 | 01:08 PM
93transam1234's Avatar
this is what i have been doing so please let me know if it is right or wrong.
1 open both bleeder valves (1 on the hose that goes to the top of the water pump 2 is on the hose that comes of the top left side of the radiator.)
2 fill radiator with coolant wait afew mintues and top off
3 fill the little coolant overflow bottle up with coolant. and replace radiator cap.
4 start the car and let it go into open loop (thermo open)
5 open radiotor cap (with car on or off?) fill as needed
6 check level in coolant overflow and add as needed.
7 with car running open blleder valve ontop of water pump and make sure a steady stream of water is comming out with no air in it.
8 close 1 st blleder valve and open second untill all air is out of the system (when i open the second one usaly i have to hit the gas a lil to make the water come out. then close blleder valve
9 sometimes i will open the radiator cap agin and top it off because of the wateri lost durring bleeding it.
Old Jun 28, 2004 | 02:03 PM
RE AND CHERYL's Avatar
That sounds fine. I'm sure GM has a set procedure, but as long as you get all the air out, it dosn't matter how you get it done.
I usually fill the radiator, open both bleeders, start the engine and continue topping off until water comes out of the bleeders.
Old Jun 29, 2004 | 12:27 AM
Lt1t56's Avatar
with engine cold and both bleeder screws open and filling radiator that should bleed 90% of the air out.
Magenta_Hearts
Mar 25, 2015 10:24 AM
grgguy
17
Feb 23, 2015 07:57 PM
kksi
Feb 17, 2015 10:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
