How big are the combustion chambers on LT1 heads?
I was thinking of getting LT4 pistons, they are 10.8:1 on 54.4 cc combustion chambers. I thought that LT1's had 58cc combustion chambers. So can someone help me out, I hope that i am just wrong.
Originally posted by rskrause
Is there such a thing as an "LT4" piston? I don't think so, aren't they identical to the pistons in an LT1?
Rich Krause
Rich Krause
* Combustion chambers are almost identical (there was a negligible .4cc difference) Volume for LT4 Combustion chambers are 54.4cc's.....
*A gain in compression ratio, from 10.4:1 to 10.8:1, comes from machining the valve pockets in the pistons shallower than the LT1's.
This is where I read that bit of info... I'll find out about the pistons... I'm curious too.
-Mindgame
i went to the gm site and the LT1 pistons had a diff part# than the LT4, i dont have the numbers off hand. The only difference that i got was the LT4's are 10.8:1 and the LT1's are 10.4:1. I was just thinking i would go with the LT4's in a rebuild to get a slight commpression boost. Here is the LT4 piston.
12528830
High Performance Piston
This piston is for the 5.7L LT4 engine (high silicon) aluminum. This 350 .030 over-size bore, pressed pin, high performance piston has a 10:8 compression ratio with 54.4cc head chamber volume.
12528830
Wish I had checked back with this thread before spending time searching that down.
Thanks for the confirmation.
I try not to post something unless I'm 100% sure it's correct. If I'm not, I'll be sure to say so.
-Mindgame
-Mindgame
As far as volume of either chamber is concerned, it depends what standard you want to use, oem production specs, or blueprint/engrg. specs. Blueprint specs are 54.0 & 54.4. 99% of oem production blocks and heads will have extra material on them on purpose. Figure appr. 2-4 cc extra. Don't recall the numerous number of posts of this nature I have posted here.
yeah yeah yeah what ever. lt4 this lt4 that....the only thing thats any better on the lt4 than the lt1 are the heads. the pistons are of the same material. hyperputic (or whatever the crap is) they suck.
anybody that tears a engine down to build it back up for a performance gain...is stupid if they use the factory pistons. spend 200 or 300 extra bucks and do it right. .3 increase in compresion ratios might give you 3 or 4 hp.
if your going to do it do it right. forgred
oldschool
Feb 9, 2016 09:21 PM
95chwagon
Jan 13, 2015 09:19 PM
