how bad is high oil pressure
Old Jul 5, 2006 | 11:53 AM
D.M.F. Solutions's Avatar
my oil pressure has always run high.. usly around the 80 the mark but it jumps around... im just wondering if it should be somthing to be worried about with 148xxx miles on it.
Old Jul 5, 2006 | 12:01 PM
user 647483's Avatar
Re: how bad is high oil pressure
it starts at 80 and goes up or it starts at 40-60 and goes up to 80 at high rpm?
Old Jul 5, 2006 | 12:15 PM
SStrokerAce's Avatar
What oil are you running?
Bret
Old Jul 5, 2006 | 03:19 PM
Silvershark's Avatar
Mine has about 60-80 on my new engine with about 5k miles on it. I run 5-w30 non synthetic. I would rather prefer more oil pressure instead of less oil pressure.
Old Jul 5, 2006 | 04:59 PM
when i start it.. it goes up to 80
Old Jul 5, 2006 | 05:05 PM
More is not always a good thing, it could mean resistance or blockage somewhere in the oil
passages, which could lead to a lack of oil in critical places.
Wow, what kind of oil are you running?
And has it been doing this even after an oil/filter change?
Does it drop after you run for a bit, or does it go higher?
Old Jul 5, 2006 | 05:06 PM
no its alwasy ran high oil pressure
Old Jul 5, 2006 | 05:50 PM
MEAN LT1's Avatar
Bret
What he said.
Old Jul 5, 2006 | 05:57 PM
James, this is true... However I am using the white spring with a melling pump. I would expect more oil pressure with my specific setup. Most turbo setup's run around 100psi.... I dont think 80 is really all that high if you entended for a higher psi setup. If I was normally at 20psi and all of a sudden I went to 80psi then I would agree with your theory.
Either way, we need more info on your setup to get ya on the right track.
Old Jul 5, 2006 | 06:41 PM
Dave89IROC's Avatar
here is a question,
has the oil pressre been verified with a mechanical guage, or just the one in the cluster?
Old Jul 6, 2006 | 12:29 AM
WHATS THE DAM OIL??????????
This is why when I build a motor I test run the pump and set the bleed spring pressure to a set level so no matter what I have a max PSI that the motor will see all the time, hot cold whatever and then use the bearing clearances to fix set it from there. FWIW you don't need 80psi
Bret
Old Jul 6, 2006 | 12:48 AM
blackztpi's Avatar
60 psi is good. 80 continuously isn't a great thing. especially if you don't have a high pressure pump. other than losing a bit of power, it's not a terrible thing though, unless blockage is present
Old Jul 6, 2006 | 02:10 AM
SStroker thats exactly right. Thats how I had mine done. Let the clearances decide the oil pressure. My machine shop suggested I stick with non synthetic for better oil pressure as well. I havent had any issues with the engine build.... This engine has been nothing but a dream.
Old Jul 6, 2006 | 04:00 AM
1BadZ95's Avatar
Just my car motor back together tonight and we just cahnge the oil Castrol GTX 10w-40. I idle at about 60psi and at 6k RPM I pegged my Autometer Oil Pressure gauge which stops at 100psi...
Old Jul 6, 2006 | 01:28 PM
Dam boss you need to drop that oil weigth down to 5w-30 or 0w-20 or something cause that puppy is TIGHT if you have 100psi in there.
Bret
