hours? opti?
Old Oct 19, 2003 | 11:12 PM
  #16
b-stevens's Avatar
Originally posted by jasons93z
I worked under my car for 12 hours this weekend with the stock jack. Not saying its a good idea, i would actually advise AGAINST it. But its all i had at the time
at least you realize it's not the brightest idea
  #17
NewbieWar's Avatar
its about 2 or 3 inches in front of the groove that the manual says to use to jack from atleast in the front of the car.
Old Oct 19, 2003 | 11:13 PM
  #18
Kris93/95Z28's Avatar
Originally posted by b-stevens
if im not mistaken isn't that referring to something directly in front of or behind it?
Yeah the something in front of it called a FENDER
Old Oct 19, 2003 | 11:14 PM
  #19
atljar's Avatar
Yes they are referring to the metal where they "form" together the two sheets and then its sprayed with undercoating. No idea what that is called, joint of some sort.
As for the ramps, they worked on mine before i had the ground effects. Rubbed a tad, but never hurt anything. With ground effects just need some 2x4s and they still work. And no you dont need to hold them. They have a rubber base pads that prevents them from sliding.
Old Oct 19, 2003 | 11:15 PM
  #20
b-stevens's Avatar
heheh thanks for that one
Old Oct 19, 2003 | 11:16 PM
  #21
jasons93z's Avatar
You are right my friend. I just wanted my car fixed. BTW, i dont jack at those jack points, maybe its just me, but those look like weak points to me? I jack up more underneath on the chasis, its really sollid.
Old Oct 19, 2003 | 11:19 PM
  #22
b-stevens's Avatar
yeah i don't like the idea of jacking there either, i use the front crossmember when jacking the front and place jackstands to the left and right of it at the... (and thats where i'll end my sentence, im going to feel dumb as **** when somebody says the name)
Old Oct 19, 2003 | 11:33 PM
  #23
96blkform's Avatar
Ive heard that somebody has to be holding the ramps in place while you drive up on them, I didnt like the sound of that
I have had my rino ramps for around 2 years and have not once had someone hold them while I have driven up. Just go up slow and be on a straight surface and you will be fine. They have a durable rubber like pad underneath that grips like tire tread. They are the best $30 I spent, so quick and easy to get the car in the air. I would recomend getting a set. If you do get a set look for the grey set, I have heard they are wider and hold more weight. I have the black ones and they work great though.
Old Oct 19, 2003 | 11:38 PM
  #24
b-stevens's Avatar
Originally posted by 96blkform
if you do get a set look for the grey set, I have heard they are wider and hold more weight. I have the black ones and they work great though.
how high do they lift you, i was looking at some cheap ones and it said 7 inches, thank god im not claustrophobic
Old Oct 20, 2003 | 08:52 AM
  #25
96blkform's Avatar
I think it is around that height, I have the instructions at home, I can take a look. It does give you quite a lot of height, higher than a jack.
Old Oct 20, 2003 | 06:37 PM
  #26
b-stevens's Avatar
by "jack" are you referring to the stock jack for use with the spare tire?
weigh2fast4u
Jun 28, 2015 08:28 PM
jwade88
Jun 14, 2015 09:38 PM
beltrunner
May 17, 2015 10:18 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
