hours? opti?
Old Oct 19, 2003 | 10:47 PM
NewbieWar's Avatar
hours? opti?
how long will it take to swap optis? for a first timer?
Old Oct 19, 2003 | 10:48 PM
atljar's Avatar
2 hours max if you have any mechanical ability.
Old Oct 19, 2003 | 10:51 PM
NewbieWar's Avatar
so 3 or 4 for me... good to know
i go slow cause i dont wanna mess anything up, and does shoebox have any thing on this?
Old Oct 19, 2003 | 10:52 PM
RamAir95TA's Avatar
I've swapped out an opti at the track in just over an hour.
Old Oct 19, 2003 | 10:56 PM
jasons93z's Avatar
How the hell did you do it in 1 hour. Not saying u didnt
EDIT: I meant to say JUST CURIOUS
NewbieWar's Avatar
why did u do it at the track?
and how high does it need to be off the ground?will the stock jack do the trick?
Old Oct 19, 2003 | 11:02 PM
revtime's Avatar
I did not even jack the car up.
Swapped it out in about 4 hrs just piddling along, if I had really tried to go fast an hour would be doable, but you would be flat working as fast as possible.
Old Oct 19, 2003 | 11:03 PM
atljar's Avatar
An hour? You slackers, my buddy and I knocked one out in 35 min, then again we had air tools and both had done it a "few" times.
You really dont even need it in the air. Drain all the coolant out, pull fans, pull off CAI/elbow, 6 bolts on waterpump, pullies off, and then 3 bolts on opti. How easy is that
Here is a nice install page
http://www.streetillusionsracing.com.../opti/opti.htm
b-stevens's Avatar
I wouldn't use the stock jack for anything while im underneath the car, that idea scares me ****less, just get yourself a set of sturdy jack stands and a jack
or ^^^seeing that i dont know anything about optis, read the post above mine... that was 3 responses in 2 minutes, not bad
Old Oct 19, 2003 | 11:04 PM
NewbieWar's Avatar
all the jackstands i have dont fit under the car while ive got it jacked up as high as it will go...
and where do u put them, ive been using the little plastic thing thats cris crossed, that says do not jack here
donno where else to do it
Old Oct 19, 2003 | 11:06 PM
atljar's Avatar
That really means "Place the jack right here". I think most of use those to jack on, lol.
Go to wallMart and buy a set of rhino ramps. $25 or so, car will pull onto them, and you will be in heaven. Great cheap tool
Old Oct 19, 2003 | 11:08 PM
b-stevens's Avatar
Ive heard that somebody has to be holding the ramps in place while you drive up on them, I didnt like the sound of that
Old Oct 19, 2003 | 11:09 PM
jasons93z's Avatar
I worked under my car for 12 hours this weekend with the stock jack. Not saying its a good idea, i would actually advise AGAINST it. But its all i had at the time
NewbieWar's Avatar
k u say those fit... all the ones my dad had purchased for his integra, (didnt fit on the integra) dont fit under my car bumper hits before the tires do
Old Oct 19, 2003 | 11:10 PM
b-stevens's Avatar
if im not mistaken isn't that referring to something directly in front of or behind it?
