View Poll Results: Which cam is for me?
LT4 Hotcam Kit
7.41%
XE 224/230
25
92.59%
Voters: 27. You may not vote on this poll
Hotcam vs. XE224/230 Poll
Old Feb 17, 2004 | 06:26 PM
AdamZ1LE28's Avatar
Emissions is an issue. Streetability is an issue. I want a driveable car for around town that can waste all the idiots with their turbos and nitrous and all the junk. I will be keeping stock heads.
Old Feb 17, 2004 | 06:32 PM
Valkyn71's Avatar
My XE224/230 is sitting at home waiting for install, i did alot of research and it should fit the bill for what your looking for. Make sure to get it on 114 LSA tho if you need to pass emissions.
Old Feb 17, 2004 | 06:37 PM
stereomandan's Avatar
Both will do the trick, but the XE224/230 has more potential.
I like something in between, the XE218/224, but the XE 224/230 is a great cam.
Dan
Old Feb 17, 2004 | 06:42 PM
AdamZ1LE28's Avatar
What's the RWHP difference between hotcam kit and a 224/230 with 1.6 rr's and everything else that comes with the hotcam?
Old Feb 17, 2004 | 06:43 PM
Daryn95Z's Avatar
224/230. It's a great street cam with tons of low end power and pulls up to around 6200 rpms. Any future mods will compliment this cam very nicely!
Old Feb 17, 2004 | 06:44 PM
With 1.6 rr's, springs and stock heads the Hotcam puts down about 325 rwhp and the XE224/230 will put down closer to 340 rwhp with stock heads.
That's assuming that you have full exhaust first (headers, and catback) and a pcm tune.
Dan
Old Feb 17, 2004 | 06:49 PM
Bersaglieri's Avatar
I voted 224/230, more power for the money. Just check out Javier97Z28 who runs 12.06 with it on stock heads with an A4. Very impressive and that will be my route to horsepower heaven. But if you dont have headers yet, I do recommend them.
-Dustin-
Old Feb 18, 2004 | 02:49 AM
unTAmedLS1's Avatar
i ran a 12.6 @ 114mph with a 2.3 60' untuned..now I have tires and the juice so we'll see what happens
Old Feb 18, 2004 | 07:41 AM
DR.ZED's Avatar
No votes for the 221/227, .542/.560 on a 112?
Can't wait for startup on mine!
Old Feb 18, 2004 | 11:15 AM
Fastbird93's Avatar
If you're staying with the stock heads, the 218/224 will more than likely out perform all other listed cams in terms of driveability, powerband, and emissions. Couple of bolt on cars with the 218/224 making about 343/343 at the wheels now.
Just my $.02
Old Feb 18, 2004 | 01:14 PM
Rich_z28's Avatar
I like the looks of the 221/227 also, but with him having to pass emissions, I think it might be a problem. I wanted to run that cam in my A4, but Seth said it'd be too much without a torque converter.
Old Feb 18, 2004 | 01:35 PM
GREGG 97Z's Avatar
You will really need headers first to see some good gains from either cam. Without them I don't think you'll be happy with the gains you see from either cam. The 224/230 is the bigger of the two cams, the Hotcam is 218/228. So if your looking for the most power that would be your choice. I'm not going to say the hotcam is the better cam or anything but I'm happy with it so far. It's up to you.
Old Feb 18, 2004 | 02:04 PM
Shon Herron's Avatar
HOT cam here but want more. Times in sig. Put down 340RWHP with it rich and on stock PE/RPM Table.
HarleyZ28
Oct 5, 2015 06:23 AM
MDZ28
11
Sep 24, 2015 09:15 AM
NewsBot
Jul 3, 2015 02:10 PM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
