Hotcam track results!
Old Mar 3, 2003 | 06:25 PM
FBODYNUT's Avatar
Thumbs up Hotcam track results!
I'm posting this for my brother 96-RAM-AIR, he will add to it when he gets off work tonight. We took his car to Alabama International Dragway yesterday and got the following run from it.
60ft 1.71
1/8th 7.9x
1/4 12.42 @ 109.9mph
That was the only good run, the second run had a crappy 60ft and was a 12.68 at a little over 110. The mods to the car are as follows. CFH stage one LT1 heads, LT4 hotcam kit, hooker long tube header, borla exhaust, FLP level IV trans, Vig 3200 stall, 3.73 gears, ed wright PCM, electric water pump, and a SLP cold air kit. The run was made on 17x9 WS6 wheels all the way around with nitto Dr's on the rear. Race weight was 3660lbs. I know the car has a 12.2x in it with some more tuning and a few other small details, ie plugs, wires, fuel filter change, manual converter lock switch. I just wanted to let all the people that are thinking about the hotcam know that it is a worthwhile mod.
Old Mar 3, 2003 | 06:42 PM
Teal94Z's Avatar
Nice times, get that 60 ft down....
Old Mar 3, 2003 | 06:45 PM
stik6shift93's Avatar
Hmm have you had it dyno tuned? I know of a guy from a local club that has a hotcam only in his full weight car and it runs 12.3s. Do you have flow number on those heads
Old Mar 3, 2003 | 07:07 PM
WheelmanZ28's Avatar
12.3s on a car with ONLY a Hot Cam Kit
Old Mar 3, 2003 | 09:12 PM
FBODYNUT's Avatar
Holy crap, that dude probably has the stock headed hot cam record. What are the other bolt on's he has? The car hasn't been on a dyno yet, it has an ed wright PCM. I don't have the flow numbers on the heads, my brother will post them when he gets on to add his .02
Old Mar 3, 2003 | 09:17 PM
96cam4ro's Avatar
It can be done with a high stall converter and weight reduction.
Old Mar 3, 2003 | 09:23 PM
95BlackTA's Avatar
Edit: nevermind!
But that sounds cool..i cant wait to get my stupid hotcam kit installed! Its still sitting under my bed
Old Mar 3, 2003 | 09:36 PM
LT1Brutus's Avatar
12.3s aren't TOO uncommom w/ a well setup car. Most people @ sea level see 12.5s w/ a good setup.
I believe the record was a 12.07 but I don't remember who did it.
Old Mar 3, 2003 | 09:53 PM
Supermanx500's Avatar
Man..nice times...I live in birmingham and go to that track a lot. Have you even been to Nationals in Downtwn Birmingham on Sat. Nights?
I am about to put in a cam but a little stronger of a cam with a whole new top end set up. Hope my times are that good! I need some Drag Radials.....or I will have no traction!
Old Mar 3, 2003 | 10:02 PM
neil350's Avatar
Congrats! I'm sure your brother has a lot left in that beast.
12.07? Isn't the bolt on no cam record Sar2Ks 11.9?, I'm sure some one can muster out a better time than that.
Old Mar 3, 2003 | 10:27 PM
EXACTLY, but he said ONLY the Hot cam kit
Old Mar 3, 2003 | 10:30 PM
Ken95Z28's Avatar
Sark's has the bolt on record.
I have one of the fastest HotCam around . Well use to, I went on to bigger things.
Old Mar 3, 2003 | 11:15 PM
blkn'silver94's Avatar
Ken, sir..you are my idol!!!!!
just out of curiousity, i have a very similar setup to yours, why did you go with 3.42's instead of 3.73's?...i have the 3.73's with a 2200 RPM stall...could i possibly see times close to yours?
Old Mar 4, 2003 | 12:00 AM
96-RAM-AIR's Avatar
thanks,im really happy with the results of this past weekend.i hope i can run a 12.2x with a little weight reduction,im gonna take it to a dyno soon and ill post the numbers,then im putting my wet kit on and go tear something up for sure
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 27, 2015 09:58 PM
Boss002
Jul 24, 2015 10:47 AM
birdblack
Jul 8, 2015 07:23 AM
