Hotcam track results!
I'm posting this for my brother 96-RAM-AIR, he will add to it when he gets off work tonight. We took his car to Alabama International Dragway yesterday and got the following run from it.
60ft 1.71
1/8th 7.9x
1/4 12.42 @ 109.9mph
That was the only good run, the second run had a crappy 60ft and was a 12.68 at a little over 110. The mods to the car are as follows. CFH stage one LT1 heads, LT4 hotcam kit, hooker long tube header, borla exhaust, FLP level IV trans, Vig 3200 stall, 3.73 gears, ed wright PCM, electric water pump, and a SLP cold air kit. The run was made on 17x9 WS6 wheels all the way around with nitto Dr's on the rear. Race weight was 3660lbs. I know the car has a 12.2x in it with some more tuning and a few other small details, ie plugs, wires, fuel filter change, manual converter lock switch. I just wanted to let all the people that are thinking about the hotcam know that it is a worthwhile mod.
60ft 1.71
1/8th 7.9x
Originally posted by stik6shift93
Hmm have you had it dyno tuned? I know of a guy from a local club that has a hotcam only in his full weight car and it runs 12.3s. Do you have flow number on those heads
12.3s on a car with ONLY a Hot Cam Kit
Man..nice times...I live in birmingham and go to that track a lot. Have you even been to Nationals in Downtwn Birmingham on Sat. Nights?
I am about to put in a cam but a little stronger of a cam with a whole new top end set up. Hope my times are that good! I need some Drag Radials.....or I will have no traction!
Ken, sir..you are my idol!!!!!
just out of curiousity, i have a very similar setup to yours, why did you go with 3.42's instead of 3.73's?...i have the 3.73's with a 2200 RPM stall...could i possibly see times close to yours?
thanks,im really happy with the results of this past weekend.i hope i can run a 12.2x with a little weight reduction,im gonna take it to a dyno soon and ill post the numbers,then im putting my wet kit on and go tear something up for sure
Louey
Pacific
Aug 7, 2015 01:47 AM
Louey
Pacific
Jul 21, 2015 10:06 PM
. Well use to, I went on to bigger things.
