hotcam and RR ratio
Old Jun 7, 2003 | 11:52 PM
  #16
delbuort's Avatar
Too late, I already got the springs (lt4 springs), retainers, shims, and keys. I got a great deal on them from a friend. Picked up the entire package still in the box for $30.
Anyone have an opinion on the RR I listed above?
Thanks,
Jason
Old Jun 8, 2003 | 08:21 AM
  #17
Dave Feerst's Avatar
you really cant go wrong with any crane or comp cams 1.6 rocker.
the comp cams tend to be stronger and the crane tend to be lighter, The roller is only good for about 2 HP.
Old Jun 8, 2003 | 10:19 AM
  #18
FastZinTennessee's Avatar
I think the cheap springs you saw in Jegs are the non self aligning kind, I'm not real sure, but just to be safe I would buy the GM roller rockers. I think they are made by crane, but nevermind that. Go to www.gmpartsdirect.com and search for part number 12370839. That is what you need, about $260. Bolt it on and go. These are what come in the HOTcam kit.
I know the prices add up, but believe me, you don't want to piece a kit together from all kinds of diferent sources if you're really not sure what you are getting. Think of how bad it would suck to get the motor apart and have a part or parts not work, and be stuck like that.
The HOTcam kit part number is 12480002. You can look it up on www.gmpartsdirect.com and it gives a breakdown of every part number included in the kit.
Hope this helps
John
Old Jun 8, 2003 | 01:55 PM
  #19
delbuort's Avatar
John,
I know what your saying...I'll check out gmpartsdirect and see what I can get. Thanks for the info.
As for the RR at Jeg's, this is what the write up says about them...
-Part# 778-66915C Small block with centerbolt valve covers, 1.6 Ratio, 3/8" stud, self-aligning ($189.99)
When I called Jeg's, they said that these would work fine in an LT1, but that was before I decided to get the cam and I was just planning on RR's. (Just FYI for anyone that wants to buy some 1.6 RR's)
Later,
Jason
Old Jun 8, 2003 | 02:06 PM
  #20
yorkie's Avatar
E bay has....
Roller rockers for 140.00 self aligning too. Check it out, they are brand new too.
Old Jun 8, 2003 | 06:35 PM
  #21
Oh one other thing about roller rockers, the seem to extend the life of valve guides because the valve rocks less.
I say you get the kit, The rockers you are getting in the kit are basicly the 329.00 crane race rockers only not colored....
Old Jun 8, 2003 | 10:04 PM
  #22
yorkie's Avatar
I had 130,000 on my stock heads on my 1995 z-28 and the guides looked ...
Perfect, a valve job, grind seats and vales and tips and back together, and these were stamped 1.5 rockers...
Old Jun 9, 2003 | 07:40 AM
  #23
they will alway look perfect, you check them with a ball gauge and a micrometer. your looking for .002 to be out of spec, of course they always look perfect. BTW the higher the valve lift the harder it is on your valveguides...
Old Jun 9, 2003 | 11:16 AM
  #24
yorkie's Avatar
they were ball guaged and all the...
guides were good at 130,000.
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
RUENUF
Mar 13, 2016 03:37 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
