hotcam idle vacuum ?
so i got a hotcam and sometimes the car will idle smooth (at about 900rpm)for a bit then will break up and idle erratic between about 6and 1100 rpms. could this be due to low vacuum causeing the erratic idle or something else?
where should i start looking, valve adjustment (how much past 0 lash should i adjust for a hotcam) all hoses are on and seem to be in good shape. the intake was put on with plenty of sealant. anywhere i should look around the throttle body? what about the idle adjustment screw, should i mess with that any?
throw some suggestions my way, thanks
Re: hotcam idle vacuum ?
Should see somewhere around 14-15" at idle with that cam. Try readjusting the rockers with the motor running and go 1/4" past zero lash.. lock em down tight.
Ring should seat almost instantly. If you have 500 miles and are still burning oil then thats a big problem.
not burning oil, i just didnt know if they would need more time for a better seal. (im a new engine newb) anyway, ill recheck the lash, i think its at 1/2 past 0, but there isnt anything to "lock down tight". rockers are comp magnum 1.6 roller tips.
its about time i had an easy fix. i'll prolly tweak the valves sometime to get a bit more vacuum, but so far so good i think. i am wondering if a little cam surge at idle is normal for a hotcam or not, but overall its improved a lot.
14
Aug 11, 2015 12:03 PM
whitehooptie
Jul 12, 2015 06:10 PM
