hotcam
Old Jan 27, 2008 | 10:41 AM
  #16
Z-RATED94's Avatar
Originally Posted by mdacton
I would go with a stock timing chain.
Get a good pushrod....summit has a good one under there brand that is cheap $85 or so in a 7.150 .083 cm
Get a better valve spring too...the springs in the kit are not very good. You will like that cam, its a good set-up IMO
Some good advice here! Do it right the first time.
Old Jan 27, 2008 | 12:55 PM
  #17
plattted's Avatar
hot cam
use the GM parts for this swap they are the best! I put the hot cam in my '93 with GMs 1.6 RRs, springs ect.. there is so much over hyped- junk stuff out there - Im sure you have read the horror stories. The hot cam makes great power and passes CTs emission testing. Go to shoeboxes site for more info on cam swapping. on my '93 i had to grind a little off the dowl pin on the front of the cam- very easy.
HarleyZ28
Oct 5, 2015 06:23 AM
MDZ28
11
Sep 24, 2015 09:15 AM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
stngh8r
West South Central
Oct 22, 2002 03:44 PM
