SES light and 6th gear cruise
Old Jan 26, 2008 | 02:47 PM
Camm95Z28's Avatar
Hello there, this is a funny situation that I hope somebody has experience and answers about.
When cruising in 6th gear/low RPM's in my 95 Z, my SES light comes on, then goes off upon city driving or when I shut the car off.
Any takers, thanks in advance.
Old Jan 26, 2008 | 02:54 PM
No subsitute for a scan, but I'd guess its for the EGR system flow code. The PCM can only run the diagnostic for EGR flow when the engine is operating under extremely steady operating conditions. MAP must hold steady for 1.5 seconds, and throttle position must be between 5 - 20% with no change preceding initiation of the test. These are the conditions that are most likely to occur during a low RPM "cruise".
Old Jan 26, 2008 | 03:25 PM
Stl94LT1's Avatar
I'm betting on the EGR code also. Mine does the same thing.
Old Jan 26, 2008 | 08:31 PM
guest74777's Avatar
Guest
mine did the same thing until I got rid of egr..I was always like wtf is wrong with this thing now
Old Jan 26, 2008 | 08:56 PM
95LT1conv's Avatar
Had the same problem. Pulled off the EGR valve and cleaned it. Haven't had a problem since.
Old Jan 26, 2008 | 09:48 PM
greenmachinedriver's Avatar
i had the same problem with mine after i added headders and deletd the cat, i took off the egr and cleaned everything and nothing changed. my theory is that there was not enough back pressure for the egr system to work properly after the mods.
Old Jan 26, 2008 | 10:29 PM
Zeueses 97 RamAir's Avatar
Egr
Its your EGR get new One or delete it out..
Old Jan 27, 2008 | 01:20 PM
Camm95Z28's Avatar
Thank you. Yes I had the same thoughts along the lines of" what is wrong with ya now?" Thanks again guys.
Gtpguy
Jan 26, 2015 04:50 PM
ChrisFrez
Dec 7, 2014 06:01 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Rich_z28
Sep 13, 2002 03:35 PM
Z28Wilson
Aug 1, 2002 04:27 PM
