hotcam with 1.7 rr's
Old Apr 19, 2004 | 09:56 PM
chy20k1's Avatar
will i see any gains that would be reason enough to use 1.7 rockers with the hot cam?
Old Apr 20, 2004 | 05:43 PM
Fast Caddie's Avatar
I read over on one of the vette forums a fella with an LT1 vette and hotcam kit changed out the 1.6s for 1.7s and gained another 15rwhp... has dyno sheets to prove it too. I'd venture to say you could gain upwards of 20rwhp with them on the stock cam.
Old Apr 20, 2004 | 05:45 PM
drewstealth's Avatar
yes i would try them out on the hotcam. I'm gonna try some 1.7rr's on my stock cam. I just wanna see what kind of power i can get as a bolt on car. Well sort of still a bolt on. Unless you count poping off the valve covers as an internal mod.
Old Apr 20, 2004 | 06:49 PM
brain's Avatar
Drew - I just saw this post, after the one you had about getting dyno'd with LT today. Do you have the 1.7s yet? If not, when do you plan on getting them? I am in the middle of putting mine on right now. I will let you know what it does on the dyno this weekend hopefully. I'm shooting for 330 rwhp with bolt-ons.
Old Apr 20, 2004 | 10:07 PM
Lift with stock cam and 1.5s: .447 int/ .459 exh
1.6s: .477/.490
1.7s: .507/.520
That's a pretty substantial increase in lift.... almost hotcam territory. From some of the results i've seen on here from 1.6s (10-15rwhp), i'd say the 1.7s have the potential to hit 20rwhp. Might even help fatten up the torque curve in the higher rpms since the stock cam's lack of duration and overlap choke it.
Who knows, an M6 with LTs, CAI, cutout, electric WP, and 1.7s might hit 320rwhp with a good tune.
As for the hotcam:
lift with 1.6s: .525/.525
1.7s: .558/.558
Might bump you up to 340rwhp or so.
I wanted to get these with LT4 springs this summer (can get everything needed for under $300, including the rockers, GPs, seals, etc). But current budget shows that i probably better not
Old Apr 20, 2004 | 10:17 PM
disco192's Avatar
I know a guy thats running mid 10 in a bolt on LS1. That is if you consider the 200 shot that he bolted on. Im just playing, lol.
Cams, cranks, rods, pistons, and heads are internal. Everything else minus nitrous is bolt on IMO.
Old Apr 21, 2004 | 08:11 AM
hvyss's Avatar
what kind of lift will you get with the 230/236 XE cam? On 1.6 rockers I have .544/.555. My AFR heads have Comp Cams .650 lift valve springs. Will they work?
HVY SS
Old Apr 21, 2004 | 09:44 AM
speedmiser's Avatar
I think you can get the lift with 1.7s by dividing the your 1.6 lift by 1.6, then multiplying by 1.7, which gives .578/.589
Someone correct me if I'm wrong though.
Old Apr 21, 2004 | 09:55 AM
Somnambulist's Avatar
Re: hotcam with 1.7 rr's
I'm assuming you have to take emissions into consideration...because otherwise it would be better to go with a larger lift cam and 1.5 or 1.6 rocker ratios to equal an equivalent to a hotcam and 1.7 rockers...it's better on your valvetrain...
Old Apr 21, 2004 | 04:34 PM
chy20k1's Avatar
you got the formula right but you multiplied wrong or you were thinking of the wrong cam. 525/ 1.6 = 328 328 * 1.7 = 557
Old Apr 21, 2004 | 11:33 PM
speedmiser's Avatar
The numbers I gave are correct for hvyss. I was answering his question about the lift on CC XE cam he mentioned, not the hotcam. He gave .544/.555 with 1.6s
Old Apr 22, 2004 | 12:10 AM
BiGGinZ's Avatar
Would it be possible to pass emissions (Cali) with the hotcam and 1.7's? I know with the hotcam you can but with the 1.7's too? That is the set-up I wanted to do.
Old Apr 22, 2004 | 01:15 AM
scoobysnax83's Avatar
where are you guys finding these 1.7s?
Old Apr 22, 2004 | 05:09 AM
KillinFormula's Avatar
I have the LT4 hot cam kit on my car, what would i need to change to be good to run the 1.7s or can i just put them on and not have to worry?
Old Apr 22, 2004 | 05:44 AM
nothing else needed, just a good tune afterwards to fully utilize them
