Hotcam for $50
Old Jul 20, 2008 | 04:34 PM
  #31
seawolf06's Avatar
Yeah, if you're doing ok now with the dry shot. Get your computer tuned for them, obviously.
Old Jul 20, 2008 | 09:29 PM
  #32
Z-RATED94's Avatar
Originally Posted by pyro719
I have a mallory 685 but I dont think it works, guess Ill send it to them to get refurb'd. What size injectors?
My first 685 came bad from the factory, they replaced it. I run the svo 30# injectors on my car with the same pump you have. Get a tune for the new inj. and cam, NA. Then pull timing with the box for the nitrous.
Old Jul 21, 2008 | 10:50 AM
  #33
pyro719's Avatar
Is there any way to make sure this cam is a true lt4 hotcam? like numbers stamped in it? part #?
Old Jul 21, 2008 | 09:21 PM
  #34
pyro719's Avatar
Well the guy says this a reground hot cam from willhoite's cams in Oklahoma it appears to be a forged cam? Its heavy. On the back of the cam it reads like this.
1264
15
9006
gmpt bc
with some weird barcode symbol thing on the bottom?
It has no fuel pump lobe but where the lobe should be reads,
.gmpt.bc.15...264.gmpt.bc.15
I have no idea what any of the numbers mean? Does anyone know how I can find out the specs of the cam?
Old Jul 21, 2008 | 09:31 PM
  #35
seawolf06's Avatar
If he "reground it", assuming it could be done, all he did was make it smaller. That cam is probably garbage.
Old Jul 21, 2008 | 11:14 PM
  #36
pyro719's Avatar
****! Good bye $50
Old Jul 22, 2008 | 12:26 AM
  #37
Z-RATED94's Avatar
****! Good bye $50
It could have been way worse than that. You could have someone put it on a cam doctor to find the correct specs, but that will cost you too.
Old Jul 22, 2008 | 08:41 AM
  #38
seawolf06's Avatar
That would be the first thing I'd do before trying to put it in my motor.
Old Jul 22, 2008 | 10:58 AM
  #39
pyro719's Avatar
I called this willhoites cams in oklahoma and they are getting back to me with the specs of the cam I only got to talk to an employee.. I also called my local GM parts dealer and they can't find the part # I gave them in their database. From what I understand the stock cams are cast and this one is forged I'm hoping these guys grind off new cam blanks?
Old Jul 22, 2008 | 02:14 PM
  #40
pyro719's Avatar
This is what my cam looks like except it has the numbers ?I posted in the previous post. https://www.camaroz28.com/forums/sho...ght=lt4+hotcam
Old Jul 23, 2008 | 09:41 AM
  #41
pyro719's Avatar
Well the cam grinder told me the specs on the cam and they match the hot cam specs, Should I still get it cam doctor'd? Its like $80 to get it doctor'd
Old Jul 23, 2008 | 10:56 AM
  #42
Z-RATED94's Avatar
If you trust him and that's what you wanted for a cam, put it in. The price was right. My buddy's car ran low 12's with full bolt ons, stock heads, and that cam.
Old Jul 23, 2008 | 11:16 AM
  #43
pyro719's Avatar
Yea I dont trust the cam grinder he sounded like an old as man from oklahoma, I'm in colorado so I have no idea if he's reliable. The specs he stated did match the cam paper that came with the cam.
Old Jul 23, 2008 | 01:43 PM
  #44
seawolf06's Avatar
He reground the cam, but it's the same specs?
Why were you searching for specs when you had the cam card?
Old Jul 23, 2008 | 02:01 PM
  #45
pyro719's Avatar
Its not a card its just a piece of paper with all the spec printed out on it. I"m just trying to make sure this cam's legit before installig it.
HarleyZ28
Oct 5, 2015 06:23 AM
MDZ28
11
Sep 24, 2015 09:15 AM
k1996z28
Apr 13, 2015 06:54 PM
WildRidez
Jan 16, 2015 03:10 PM
stngh8r
West South Central
Oct 22, 2002 03:44 PM
