Hotcam for $50
Old Jul 15, 2008 | 03:57 PM
pyro719's Avatar
Hotcam for $50
I came across a brand new hot cam for $50, Would it be worth it to add this to my mods or should I wait and put a cc503 in it? He also has a brand new lt4 intake manifold for $300 are they worth the money?
Old Jul 15, 2008 | 04:33 PM
kyle88transam's Avatar
$50 is a pretty good deal, but keep in mind you will still need springs,retainers, and at least pushrods. The lt4 intake will not work without lt4 heads the intake runners are taller on the lt4's.
Old Jul 15, 2008 | 04:58 PM
seawolf06's Avatar
Is it a stock LT4 cam or an LT4 hotcam? They are not the same thing.
Old Jul 15, 2008 | 05:22 PM
pyro719's Avatar
LT4 hotcam that comes with the hotcam kit. I already have lt4 springs and retainers and its a 94 so it should have hardend pushrods.
Old Jul 15, 2008 | 08:09 PM
seawolf06's Avatar
Well, the LT4 springs won't work with the cc503, so unless you want to buy new ones, you might as well get the hotcam.
Old Jul 15, 2008 | 10:41 PM
LSWHO's Avatar
are you kidding?! Buy it and sell it! You could make a quick $200. I'll buy it right now!
Old Jul 15, 2008 | 10:50 PM
96' Formula WS6's Avatar
If you wanna buy it from him thats totally up to you. But id rather spend an extra 60 bux and get a little better cam from Thunder racing or something like that. just my .02
Old Jul 15, 2008 | 11:03 PM
LSWHO's Avatar
ooooh... i misread your post #4. I though it read "that LT4 hotcam comes with the hotcam kit" Meaning it was the whole kit for only $50.
I wouldn't buy it.
Old Jul 15, 2008 | 11:27 PM
BCdawg57's Avatar
are you buying this from someone you know or on here? I know of some scammers on this site and would be leery of any deal that good.
Old Jul 15, 2008 | 11:47 PM
pyro719's Avatar
Getting it from a guy I know. He was going to put the whole hotcam kit on his untill he wrecked it.
Old Jul 16, 2008 | 07:53 AM
seawolf06's Avatar
Where are you going to get a cam for $110? Not TR I don't think.
He would also need all new springs and roller rockers.
Old Jul 16, 2008 | 12:37 PM
pyro719's Avatar
The only things I am concerned about is that people say the springs that come with the hot cam wich I have installed right now, are not strong enough for the hot cam? That and the fact that I hear alot of horror story about spun bearing on higher mileage engines when a cam is swapped in?
Old Jul 16, 2008 | 01:00 PM
'94 Bad A Z28's Avatar
You have crappy 3-piece "hardened" pushrods. Replace them, get some Comp 1-piece hardened at least.
Old Jul 16, 2008 | 01:17 PM
seawolf06's Avatar
The hotcam kit springs will work fine with the hotcam. That's why they're sold as a kit.
Many people, including myself, have had bearing problems when installing cams on higher mileage engines. Most failures seem to be caused by running the RPM higher and having more power. There's no way to know for sure if your motor will hold up or not.
I agree about the pushrods as well.
Old Jul 16, 2008 | 01:41 PM
pyro719's Avatar
What about the pushrods?
